Can 4 channel axles be used in a 3 channel rear end?
Old 04-15-2014, 10:13 PM
HotWhipT/A's Avatar
Default Can 4 channel axles be used in a 3 channel rear end?
I've done several searches and I have found a lot of answers to many of my questions, but I have a few remaining. I've never done rear end stuff before.
Here's the deal, I have two 6spd Trans Am's. My new daily has a 3 channel rear with at least 1 bent axle. My nice fast TA has a 4 channel rear. What I want to do is replace the good axles in my 4 channel rear with some nice Moser axles...4 channel also of course. I want to then install the good stock 4 channel axles in my other TA with the 3 channel rear that has bent axles.
I've read the only difference between the 2 axles is that the 4 channel ones have a reluctor wheel. Is the reluctor wheel removable? If not, will those axles work in a 3 channel rear? Is there anything else that I should replace when changing the axles?
Old 04-15-2014, 10:44 PM
Rob WS6's Avatar
Yes they'll work fine, and yes you can just pop off the reluctor wheels with a bit of heat and a little even prying, but you wont need to, you can just leave them on... they wont interfere with anything.
Old 04-16-2014, 01:28 AM
HotWhipT/A's Avatar
Do new Moser axles for 4 channel rear come with the reluctor rings? They have 2 options for axles...3 or 4 channel. The 4 channel costing more. I would think they come with them considering but I'm finding no detailed info for sure.
Old 04-16-2014, 06:09 AM
FirstYrLS1Z's Avatar
Axles are the same.
Moser replacement axles do not come with rings. use the rings from existing axles to put on the moser axles.
Old 04-16-2014, 02:11 PM
01ssreda4's Avatar
There is a pic floating around somewhere of the flange area. 4 channel axles have a machined surface for the ring to grab, 3 channels don't, that's the only difference between the two.
Old 04-16-2014, 03:27 PM
here's that pic
Old 04-16-2014, 03:58 PM
01ssreda4's Avatar
That's a good pic.
Old 04-16-2014, 04:32 PM
Old 04-17-2014, 03:54 AM
HotWhipT/A's Avatar
I bought some USA Alloy axles. I'm just going to put them in my daily with the bent ones and be done with it. I really don't want to screw around with the reluctor wheels, not to mention twice the work.
Quick Reply: Can 4 channel axles be used in a 3 channel rear end?
