rear end seal
Old 06-19-2014, 05:13 PM
tatergreer13's Avatar
Default rear end seal
on the stock 10 bolt cover should i use a gasket or rtv?
Old 06-19-2014, 05:50 PM
M4N14C's Avatar
Both?
I used a paper gasket, put some RTV on the edges, put the cover back on (don't over torque it) then used more RTV to make sure nothing comes out.
Old 06-20-2014, 06:33 AM
Ok cool and it calls for 3.6 pints but i keep hearing people putting 2 quarts and a limited slip additive if the gear oil i am using is limited slip do i still need the additive
Old 06-20-2014, 09:07 AM
It's not mine! woo hoo!
demonspeed's Avatar
You only need the additive if you have a clutch pack style differential. That would only include 98's if everything is stock. Otherwise, 99-02 will have a Torsen*. The Torsen T2 recommends 75-90 synthetic. Use conventional gear oil and additive with a clutch pack style. Do not overfill -- just add until fluid comes out of the top hole on the passenger side the housing.
*SS/Firehawk could have an Auburn with the clutch packs as a SLP option. You would want to use the additive if so.
Old 06-20-2014, 05:49 PM
well i have 2 quarts of valvoline 80w90sae limited slip do i still need the additive
Old 06-20-2014, 05:50 PM
my car is a 98 with a factory 10 bolt
Old 06-20-2014, 06:11 PM
joecar's Avatar
I use the GM fiber gasket since it is thicker than the Felpro paper gasket. No RTV.
Your Valvoline 80W90 LS already has limited slip additive in it (that's why it says Limited Slip).
http://www.valvoline.com/pdf/high_performance_gear.pdf
Old 06-23-2014, 10:02 AM
demonspeed's Avatar
Do not use it if it is synthetic since you're a 98. You need to use conventional gear oil with the additive instead.
Quick Reply: rear end seal
