Best way to seal up diff cover?
So a few months ago I went to drain and fill my differential fluid. I used some gasket maker sealant on the cover and it still made a leak after I drove it. So now, I took the cover off again and want to make sure it has a good seal.
What's the best way to seal up the 10-bolt diff cover on our cars? RTV sealant? paper gasket? double gasket?
Torque the bolts to 22 ft. lbs. in a criss cross pattern right? Thanks for any input
Just use ultra grey rtv. You don't need a huge bead. Just finger paint it all over the cover, let it skin up a few minutes then try to place it on squarely. The panhard bar makes it difficult to get a straight shot without scraping anything, but it can be done. Make sure the housing surface has no oil on it. Sop the excess out of the housing with a rag to prevent drips while placing the cover on.
Figure out why it didn't seal in the first place. The normal cause is it's been over tightened. Take a close look at it where the bolt holes are, if any of the holes are dimpled then you'll need to straighten the cover.
Double gaskets is NEVER the right answer. Doesn't matter what it's on.
