Dyno difference between S60 and 9"?
Does anyone have any data on this? I'm very curious and wondering as I get close to buying one of these. I'm looking at the Moser 9 (not fabbed) or the S60 with my A4.
In-Zane Moderator
The 60 eats more power and is a little heavier usually. Not enough to be able to tell with allot of power. A 12 bolt will eat the least power usually and is fine for many running much faster than I ever will. Seen them all go 7s in the 1/4 and seen them all break running 9s with some tire shake.
Wow guys. I've heard a lot of negative talk about the 12 bolt, but I've seen positive feedback as well. I would like to go with a 12 bolt but had kinda ruled it out with everyone talking about the torque arm issue and noise.
They seem to be fine behind the A4 noise wise and with UMI's new kit the TA problem should be less of an issue. I recently dropped the coin on a FAB9 because I have poor financial planning abilities and they're so dang pretty. But it sounds like the 12-bolt would work fine for you.
Install here:
https://ls1tech.com/forums/gears-axl...t-install.html
Here she is putting in work:
The car used in this test is not LS powered but it shows hp results between 9", dana 60 and 12 bolt.http://www.hotrod.com/how-to/transmi...ear-axle-swap/
The problem is most of what youre reading is repeated bullshit and not actual factual advice. I do not regret my 12 bolt purchase. I chose it, I built it, and I race it.
Install here:
Install here:
Install here:
Install here:
