8.8 build
Old 05-17-2015, 07:49 PM
All Pontiac WS6's Avatar
Default 8.8 build
Finally got my 8.8 built. Waiting on the axles and bearings. Hope to get it finished this weekend.
Old 05-18-2015, 05:38 AM
hiltsy855's Avatar
Looks great!!!
Old 05-18-2015, 10:01 AM
blackandgold's Avatar
Looks good! What is it going behind?
Old 05-18-2015, 06:11 PM
Default 8.8.
Check it out in the Firebird Section;
1998 Trans Am with a 462 Pontiac engine.
Old 05-19-2015, 09:01 AM
Dark SS's Avatar
Looks awesome.
Old 05-19-2015, 07:12 PM
dailydriver's Avatar
I WISH that someone made an affordable, RELIABLE (torque arm mounting bracket welds), BOLT IN version of this axle (NOT Hawk's).
Then I could use the STRONG, high bias, 8.8 Torsen T2R diff, in a stronger than 10 bolt axle, without all of the un-needed weight of an S60/9.
Old 07-31-2015, 06:25 AM
xXred99z28Xx's Avatar
What length axles did you use? I'm having TNT Fabrication build mine right now.
Old 08-05-2015, 07:23 PM
Default 8.8
I had my 8.8 built to factory width.
He {TNT} has a connection for the axles.
Old 08-07-2015, 08:08 AM
Rise of the Phoenix's Avatar
So did you build the rear yourself, and if so, did you opt to use the 8.8 center section and weld on the 10 bolt axle tubes? I know that's how Josh at TNT Performance does it.
Old 08-09-2015, 08:06 AM
Default 8.8
Josh built my 8.8. I rebuilt the carrier and installed all new bearings.
Old 08-10-2015, 06:15 AM
JRENIGAR's Avatar
Have you ran it yet? If so is it quiet? What kind of times did you run with it?
Old 08-11-2015, 08:07 PM
Default 8.8
My car is not running as of now. I have about 6 more months before it is up and running.
Old 08-12-2015, 08:07 AM
What gears are in the 8.8 your sourced out, and are you going to leave them, or change them out? Also, after all is said and done, how much TOTAL will you have into the rear?
Old 08-12-2015, 08:25 AM
MidwestChassis2's Avatar
It's a very nice looking rear end but I'd strongly suggest anyone building their own rear end to spend the time to put better ends on it to eliminate the C-Clip axles and purchase a rear diff cover and a brace kit.
These are all things needed to help an 8.8 survive in any chassis but be careful what rear diff cover you purchase as it may have clearance issues like some to with S60 and 12-bolts.
Old 08-12-2015, 05:56 PM
Default 8.8
Well it is finally put back together. Hope to have it in the car soon.
Attached Thumbnails 8.8 build-tn-1.jpg   8.8 build-tn-2.jpg   8.8 build-tn-3.jpg
Old 08-13-2015, 06:46 AM
JRENIGAR's Avatar
Looks nice.
Old 09-25-2015, 01:52 AM
Spectre86's Avatar
good to know. i was talking with him a bit today on fb. was going to what axles to run for a 31 spline with his setup. waiting to hear back on a few 8.8s
Old 09-25-2015, 09:45 AM
JRENIGAR's Avatar
I am working on installing my TNT 8.8 at the moment. I ordered axles from moser that will keep 4ch abs. They were for stock width and ford 31 spline diff shipped for $405.00
Old 09-25-2015, 10:16 AM
So after all the dust settles, how much money will you have in the 8.8 all together?
Old 09-25-2015, 10:24 AM
Spectre86's Avatar
is there a part number on those?
hows the rear look? I have yet to find a single negative thing anyones said about the TNT 8.8
600 plus the cost of the 8.8, 10 bolt tubes, shipping and the axles.
still probably a good grand cheaper then an entry fab 9 with a spool
Quick Reply: 8.8 build
