bent axle
bent axle
So A friend has bent his axle shattered his rim after hitting a curb when he lost control of the car during the rain. So we got a replacement rim and when he started to drive the car i noticed a squeek when closer inspection came I thought the rotor was bent because it was hitting the brake pad. Once we took the rotor off it was flat and perfect like nothing happened. So i looked at the axle hub and it was bent...
My question is how do i change the axle out. I have a new one awaiting to be put in.
Here's a quick write-up on the removal procedure. If you have an Auburn diff, it may look a little different, but not much.
https://ls1tech.com/forums/showthrea...ht=remove+axle
Here's a site showing a gear change with pics. It's a bigger ring gear axle, but the procedure is the same as our 7.5./7.625 rear axle . Skip over the parts about the gear change and check out the pics about removing the c-clips and you'll get the idea.
http://www.fullsizechevy.com/fscu/axletech/
I have a KTRE 12-bolt in my Camaro and need to pull the axles out (I think they're bent).
Aside from changing the gear oil, I've never worked on a diff / axles before and was hoping somone could tell me if the steps described above are applicable to a 12-bolt? When I had it installed I also specified a C-clip eliminator kit, will this bring me any surprises or headaches?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks for the info, will the axles really just pull out? I really should know more about how they work, but can anyone give me a lesson on how the C-clip eliminator works?
