Question on Strange 12 bolt install w/3 channel
Old 02-12-2005, 01:35 PM
DrkPhx's Avatar
Default Question on Strange 12 bolt install w/3 channel
Hi,
Need some help from people who have installed a 3-channel Strange 12-bolt.
The stock ABS sensor/module which screws on the top of the pumpkin does not fit on the Strange 12-bolt. The Strange appears to have it's own module with one black and one white wire sticking out. Do I just splice the wires from Strange to the existing wires or is this the wrong 12 bolt?
Old 02-12-2005, 03:42 PM
1ScrudeDude's Avatar
Originally Posted by DrkPhx
Hi,
I thinked we spliced into it. Don't hold me to it, but that's what I remember...
Old 02-13-2005, 12:25 AM
DrkPhx's Avatar
I spliced it.The stock sensor won't work.
Old 02-13-2005, 06:29 AM
chief455's Avatar
please post up if it works - mine is being built now!
thanks. I wonder if we can get replacement sensors at local parts stores?
Old 02-13-2005, 11:21 AM
NHRAFORMULA00's Avatar
just splice it. mine worsks fine for a whole year now
Old 02-13-2005, 02:36 PM
chief455's Avatar
and which colors did you put together?
Old 02-13-2005, 02:57 PM
DrkPhx's Avatar
There are only two; white and black for both the Strange sensor and the OEM sensor. You have to remove the pigtail which connects to the panel on the frame and to to the OEM sensor. Cut off the sensor end that connects to the stock 10 bolt. Then splice the two wires (black and white) to the Strange sensor (black and white also). I soldered mine and wrapped them good. When you are ready to install, just plug the pigtail back into the panel bolted to the frame. Hope this helps.
Old 02-13-2005, 03:09 PM
chief455's Avatar
Perfect! Thank you.
I see different replacement sensors on the parts websites. I'll call Strange and get the part number from them to buy a spare
