Rebuilt Ford 9" Trak Loc posi, worth anything?
Old 05-08-2006, 11:01 AM
silverTA2002's Avatar
Default Rebuilt Ford 9" Trak Loc posi, worth anything?
Would this be any good to use for a daily driver around 400rwhp street car?
I've got a Moser 9" with 31 spline Moser axles. But, it has a junkyard center section with 3.70 gears and a spool.
I can get a rebuilt Trak loc posi (4 pinion, steel discs) with standard case, new 4.11 motive gears and all new internals for $455 shipped. http://cgi.ebay.com/ebaymotors/9-for...QQcmdZViewItem
I'm just wondering if it's worth it. I haven't read much about the regular Ford Posi units, except that an eaton or truetrak is better. But, they're a bit more $$.
I should note that the front seal on my current unistalled 9" is leaking as well.
Old 05-08-2006, 03:53 PM
Turo's Avatar
I've read about plenty of people breaking those posi's (and those strandard housings) at the track. I would guess it would be ok if you don't go to the track much, and you don't use too sticky of a tire.
Old 05-08-2006, 04:31 PM
What kinda power were they putting down to break them?
It HAS to be way stronger than my stock rear. And that's doing fine.
Old 05-08-2006, 05:15 PM
Turo's Avatar
I believe the last one I read (about a year ago if you do a search in the drag tech section) was a cam only M6 car launching on slicks. He cracked the case right in half. I'm assumming he was around 400rwhp, not sure though.
I'm not really sure how it compares to a stock 10-bolt, but I would imagine it would definitely be stronger.
Old 05-09-2006, 12:22 PM
Well... for $455, it turns out you get a rebuilt "econo-lok." ?? (no thanks)
For $630 shipped I can get a brand new Trak loc. I'm getting prices on an eaton posi or truetrak as well.
Old 05-09-2006, 01:33 PM
chicane's Avatar
A 4 pinion with a billet side cover would be the only choice for that kinda of power..... and its ability to survive.
Old 05-09-2006, 03:17 PM
Cal
Cal's Avatar
My Trac Loc has been holding up to 430 rwhp.
Old 05-09-2006, 11:20 PM
Ok..... decisions decisions..... What would YOU do?
All for Ford 9" center section standard case, new 4.11 Motive gears, 1310 Yoke....
option 1. Rebuilt econolok $455
option 2. NEW Ford Trac Loc $630
option 3. NEW Eaton Posi or Truetrak $750
All prices include shipping.
Old 05-10-2006, 09:58 AM
Cal
Cal's Avatar
I'm running Moser 9 inch with aluminum center section and True Trac. You can get the True Trac for under $500.
Old 05-10-2006, 11:31 AM
I can get the true trac for under $400.
But, this is a complete center section with gears, yoke, everything, setup.
Quick Reply: Rebuilt Ford 9" Trak Loc posi, worth anything?
