3or 4 channel ??
Old 07-09-2006, 11:46 AM
2001z's Avatar
Default 3or 4 channel ??
I am in the process of looking for a 9 or a 12 bolt becouse of 10 bolt crapping and i need to know if mine is a 4 channel or a 3 channel . How do i go about finding what mine is i never needed to know before now .
Old 07-09-2006, 11:56 AM
2001NBMZ28's Avatar
Non-TCS cars are 3 channel with one connection on top of the pumpkin, TCS cars are 4 channel with the connections at each rear wheel.
Old 07-09-2006, 11:57 AM
Predator's Avatar
If you have traction control it's 4-channel, if not it's 3-channel. "ASR" in Camaros and "TCS" in Firebirds.
Old 07-09-2006, 12:12 PM
2001z's Avatar
ahhhh now i see thanks for the info guys . Well if i go 9in i dont think it will work with tcs anyhow from what i have seen it doesnt work to well on the applications. So if i go 9in i should get 3 channel and if i go 12bolt i should go 4 channel right ?
Old 07-09-2006, 02:11 PM
jmill96Z's Avatar
It depends where your reluctor ring(s) are. You need to keep the same system. If the rings are at the end of the axleshafts you have the 4 channel. If the single ring is mounted to the carrier, you have the 3 channel.
Old 07-09-2006, 03:12 PM
2001z's Avatar
damn i feel like a noob with rearends what the hell is a reluctor ring
Old 07-09-2006, 03:51 PM
keliente's Avatar
https://ls1tech.com/forums/gears-axles/412366-rear-end-faq.html
Old 07-09-2006, 03:59 PM
2001z's Avatar
Originally Posted by keliente
Thanks that is a good write up for noobs like me with questions on rears TCS+abs =4 channel.
