New 9": TA hitting body(driv. side rear seat bolt) HELP!!!
I just installed my new 9", mounted the TA mount in the same bolt holes as stock (there are 2) and when to put the TA in and it hits that bolt on the side of the tunnel. Anyone run into this problem? Good half inch to clear.
I tried mounting the TA bracket in the other set of holes and it wont line up.
Thanks
Ill have to call Bob monday.
Thanks
Thanks
Thanks
You mentioned an adjustable pan. bar...is it in any way bad to leave the stock..being the angle now is clearly different then the stock rearend? If its fine to be at that angle ill just bang that bolt outta the way.
The rears in these cars sit offset from the factory to one side. They also sit back in the wheelwell about .5 inch. The larger 9 inch rear does sometime require a little clearancing with a pry bar in the tunnel area, it doesn't take much. Bob
