9inch and torque arm
My question is pretty simple are the provitions for the torque arm on the moser 9inch on the third member or are they on the housing. i want to by the housing and axle from moser and then later build my own third memeber but my friends seem to think the third memeber is special due to arer torque arm.
you can use any third member as far as i know.....the housing is what is modified to accept the t/a....right now my spohn body mounted torque arm is giving me fits on the 9" moser, and i talked to another guy from this forum who is having issues with a bmr t/a on his....but others say they fit right in, so i don't know what to think right now.......
I advise people to check the torque arm fitment before installing the rear. We've used a lot of different brands of torque arms on Moser 9 inch rears, sometimes a little grinding is necessary. Bob
Just had the same issue. Apparently, the Moser 9" torque arm provisions are all over the board as far as fitment. I had a Moser 9" and had some guys try to install a Spohn tunnel mount tq arm and it took some time. The rear end tq arm provisions were off by like 3/4" that was causing some major bind when then tried to put the car down. They had to "fix" it and it was a major PITA.
Originally Posted by 02NBMWS6
it doesnt need any grinding, its just too long now
Can you get some pictures of it, so we can see exactly what you're up against. Thanks! Bob
in another thread i had about my problems:
when i had a stock rear the bottom t/a swivel and the top bushing were perpendicular, now the top is two inches too far ahead......its causing major clunking when the trans shift.....
i was wondering if the rear was in the jig wrong when they welded the tubes that the mount bolts to or what....how did they fix it? did they mess with the t/a or the mount?
Apparently they decided to fix it with the torque arm. The bracket is just a huge chunk of metal and they didn't want to fool with that. I think they called both Moser and Spohn and each one said to modify the others piece (I know hard to believe ) It probably was something messed up in the jig and Spohn actually said they had seen this before because the tubes were all over the place in mounting location on the bracket.
Post pictures of the TA mounting location on the rear not at the tunnel if you have any.
The only way to figure out what is wrong, and what needs to be corrected is to get some measurements. Some good pictures of what might be wrong would be of help. Bob
