building a 9" and have a couple ?s
Old 06-23-2007, 12:39 PM
Z28_DAD's Avatar
Default building a 9" and have a couple ?s
when it comes to spline count, more or less? which is better and why? also, where can i get axles for our wheel bolt pattern? the 9" i have is out of a 73 mach 1, so my wheels wont bolt up.
and befor anyone mentions the T/A mounts, its gone so it doesnt matter
Old 06-23-2007, 01:59 PM
14 Second Truck Club
mzoomora's Avatar
More spline generally means a stronger axle. The diameter increases with the spline also, making them stronger. Moser, Currie, Strange, Superior, etc all make aftermarket axles with the proper spline and bolt pattern.
Old 06-23-2007, 02:37 PM
Z28_DAD's Avatar
opposite of what i thought. i thought less splines means they would be bigger and stronger. but since the diameter increases with splines, that makes more sense
Old 06-23-2007, 03:07 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
What sort of rear suspension setup are you converting to?
Old 06-23-2007, 03:13 PM
Z28_DAD's Avatar
i have the lakewood traction action lift bars(ladder bars). i can adjust the pinion ange with them instead of a TA
Old 06-23-2007, 05:13 PM
00PewterSS's Avatar
Interesting I've never seen anyone use those. I'm curious how well that would work, it changes the instant center a lot compared to even a short torque arm.
Are you sure that this system will fit your 9". The tubes are a different diameter. You must be welding spring perches, shock attachment and LCA brackets on that will fit our cars... as I assume a 73 car had leaf springs. Is the width even correct?
Brian
Old 06-23-2007, 06:15 PM
OWN3D BY MY PROF!
You are aware that those like to break right? I've read of lots of guys having those break on them.
Old 06-24-2007, 01:00 AM
Z28_DAD's Avatar
improper instalation. ive had mine on for over 10k very hard miles without a problem. plus when they are welded to the 9", they will be reinforced
Old 06-24-2007, 10:07 PM
OWN3D BY MY PROF!
Have any pictures? I have a little collection going of Z bar / short ladder bar style setups.
Old 06-24-2007, 10:13 PM
Z28_DAD's Avatar
not now, but i will once i start on the 9"
