Gear change How-to...
Old 11-26-2007, 11:23 AM
KurtRardin's Avatar
Default Gear change How-to...
I recently tackled a gear swap into my 1998 Z and found these sites VERY helpfull in changing the gears:
http://www.keliente.com/gears.htm
http://www.greenfries.info/rear_gear.htm
http://www.stealthram.com/gearswap.htm
http://www.chevyhiperformance.com/te...all/index.html
Setting up gears is not hard at all, it just takes time and patience. I have never done them before and these articles were all it took for me to finish the job.
...Now its only a matter of time before my rear end explodes
Old 11-26-2007, 11:36 AM
Jays00ss's Avatar
LOL at least you have a sense of humour about the enevetable.
Old 11-26-2007, 11:55 AM
keliente's Avatar
LOL. Good luck!
Old 11-26-2007, 07:06 PM
KurtRardin's Avatar
Ah, there's the one who wrote the how-to at the top of my list! Thanks a bunch!
Old 11-27-2007, 12:27 PM
bearcatt's Avatar
Keliente ?
Old 11-27-2007, 12:40 PM
keliente's Avatar
Originally Posted by bearcatt
Keliente ?
Yep...that's me.
Old 11-27-2007, 12:50 PM
alamantia's Avatar
i dont understand this....
http://www.chevyhiperformance.com/te.../photo_07.html
Old 11-27-2007, 10:07 PM
BJM
BJM's Avatar
Originally Posted by alamantia
If you are referring to the two holes, they are for a case spreader to grab on and stretch the pumpkin open.
Old 11-28-2007, 01:57 AM
KurtRardin's Avatar
I didnt find any stretching to be needed. In fact, my foot and a half breaker bar was all that was needed to get the carrier out of the housing. Oh, I forgot to mention my two spider gear teeth I found when I pulled the cover off for the first time. Ouch. The pin gets pulled a little further from my grenade every time I step on it...
Old 11-28-2007, 05:59 AM
alamantia's Avatar
Exactly, so why would the artical tell you to make sure you find a gasket with holes in it for oil passage when no one makes a gasket with holes for oil passage. Not to mention the dif cover covers those two holes and no oil passes through those holes...
Old 12-01-2007, 08:23 AM
KurtRardin's Avatar
I wouldnt worry about it then, after all, I doubt the rear end is going to explode because it wasnt circulating oil the way that chevy high performance says it should. I think the LS1 factor is going to have much more to do with any problems related to our 10 bolts.
BTW, waiting to do 4.10s AFTER you've already done a cam, tune, and all the bolt-ons feels freakin awesome!
Old 12-06-2007, 07:02 PM
bearcatt's Avatar
Originally Posted by keliente
Yep...that's me.
You're a true Pimp-tress.
Excellent write-ups.
Quick Reply: Gear change How-to...
