what rear end do i have
i have a stock rear end on a 95 trans am. i went to get new gears and they said they needed to know what gears i have now but i found that out but they asked if it a 10 bolt or 12 bolt. what is the stock rear end. i know this thread is dumb but thanks for any help i get
If you REALLY want to know what your gear ratio is there are a few ways to do it. I have a 97 Z28 Camaro and I have 3.42 gears in mine. if you look on the drivers door, just under the lock mechanism where it holds the dor shut, there will be some stickers there. One will have a shitload of number and letter combinations on it. something along the lines of AG1 AK5 AR9 AU0, etc. and its all in alphabetical order. Go to the 3 letter combo's that start with the letter G. There will probably only be one or 2 of the G's there. Mine was a GU6 which means I have 3.42 gears.
The only options are:
GU2- 2.73 Gear Ratio
GU4- 3.08 Gear Ratio
GU5- 3.23 Gear Ratio
GU6- 3.42 Gear Ratio
That will tell you what you have so you can tell the guys working on the car. Any other codes you need to know go to http://www.fbodymotorsports.com/9302rpocodes.
ok, so congrats, you have a 2.73 Gear Ratio if it is all stock. now that you know that you know what carrier you have which is what the guys needed to know, your all set. good luck. lol
