Midwest Chassis & Performance fab rearends... new pics
#3241
Yes it is. http://www.ebay.com/itm/121766474632...84.m1558.l2649
If anyone is interested in travel limiter kit I was able to put a complete kit together and will have multiple kits by the end of this week.
#3246
Kore3 big brake kit installed onto one of our fabricated nine inch's getting ready to go out the door. Then to assemble another one with their brake kit after that. Seems like we do a couple of these a month.
#3250
If anyone is looking to build there own rear end we offer bare housings down to cores with no housing ends. Purchasing a Midwest Chassis fabricated rear end set up with F-Body brackets can save you a lot of money. Purchase a used drop out and get on the road.
#3251
Midwest Chassis Black Friday Sale just started!!! Take an additional 10% off our already low prices on all parts manufactured in-house as well as shocks from AFCO, Strange, Viking, and Menscer Motorsports!
We are also offering discounts on our fabricated rear end. $100 off the base package and additional discount on upgrades. This is the best deal we have had to date. Don't miss out and lock in your prices now with our $500 deposit and pay as you go until it's paid off.
#3252
I believe I got all the PM's answered over the weekend on rear end orders but if I missed your questions please feel to shoot me another PM please. My message box got filled up over the weekend.
#3255
If you want to take advantage of our Black Friday pricing but can't afford to make your purchase this week or even this month! This is not a problem with us, just give us a call and put down 10% of your purchase price and pay off the rest when you can. Even if it takes a few payments to do so. No interest and no hassles.
This way if it takes you some time to pay off the item you still get the discounted pricing.
#3257
Yes Ebay items are discounted already for the sale prices. Please give us a call or your number and we will be happy to take care of you. The phone has been very busy the past couple days while customers are taking advantage of the great deals.
#3260
Anyone looking for a rear end package our package includes a torque arm and crossmember. By the time you purchase a housing with out a torque arm you end up spend more.
Midwest Chassis fabricated 9-inch rearend packages are designed to work on street cars with off-road Y-pipe full exhaust, duals, and even hard-core drag cars. Our true fabricated triangulated housing incorporates technology that allows for a much stronger design than the stock stamped style housings or even other manufacturers fabricated rears without adding extra weight. All components are laser cut using all USA steel components. We offer one-off custom features as well.
SPECS:
CAD Design Components
Laser Cut
CNC folds
DOM Seamless tubing
Billet Housing Ends
Fully gusseted design (Internal bulkhead gussets and axle tube go all the way to the carrier studs, fully welded around axle tube, face plate, and housing backside)
Widest housing design (Increased strength with or without brace. 4-5" of axle tube is welded to the faceplate)
First company to offer 3-channel ABS on aftermarket 9-inch rearends
Rearend assemblies include chromoly adjustable torque arm - tunnel or transmission crossmemeber mount (Torque arm uses aircraft grade, Chromoly, Teflon lined heim joint at the front to allow suspension articulation without binding).
Transmission crossmember mounted version available for all transmission combos
Tunnel mount crossmembers are available for cat-back or true duals & include the driveshaft loop at no charge
Our torque arm is mounted to the crossmember with a 4-hole height adjustable pivot link
Street version pivot link is mounted to the crossmember with a Energy Suspension polyurethane bushing to eliminate noise
All bracketry retains stock mounting locations and geometry
The following features are included at NO additional charge:
Any available width
4 position adjustable relocator style lower control arm brackets
drain plug
stock style mounted anti-sway bar brackets installed
brake hose brackets installed
1998-2002 rearend models include e-brake cable bracket installed
brake line clips welded on
chassis brake hose adapter included
housing vent
grade 8 hardware included for all brackets - no other manufacturers do this
ARP housing studs
The following features are available for an additional charge:
Any type center section available (Nodular iron or Aluminum from Strange, Yukon, or Moser)
Narrowed lower control arm brackets available
Tapered housing backbrace installation
Drag Race anti-roll bar available (rearend housing/chassis mounted)
Industrial grade powdercoating available
Wheelie bar mounts
Transverse shock mounts
Tow Loops
Additional Remote Filler Cap
Call with any other custom needs not listed
BASE PACKAGE INCLUDES: Fabricated housing with all the standard features; 35 spline axles with standard or metric studs & tapered street bearings. Complete assembled center section with nodular iron case, billet aluminum Daytona style pinion support, lightened spool, and choice of street gear. Package also includes exclusive MWC chromoly double adjustable torque arm with crossmember for your application. Use your existing brakes. Fabricated rearend package comes unpainted.
SPECS:
Laser Cut
CNC folds
DOM Seamless tubing
Billet Housing Ends
Any available width
drain plug
housing vent
ARP housing studs
Wheelie bar mounts
Tow Loops
