Where to get a spool?
Old 03-13-2008, 09:47 PM
Texas_WS6's Avatar
Default Where to get a spool?
Who makes and who sell a spool for a stock rear end? 2002 WS6 car.
Old 03-13-2008, 09:59 PM
2002_Z28_Six_Speed's Avatar
Strange makes them. One of the sponsors will tell you who is the best priced though.
Old 03-13-2008, 10:00 PM
LS1Silverado05's Avatar
Upcoming Mods: 408(Short block completed), L92 ported heads, GMPP Intake completed for summer. 76GTS turbo but the turbo install will not be finished until end of summer at best.
Just my opinion...but if you are planning all that power. Try to wait it out for a 12bolt or 9" etc. Even if you wait to find a good deal on a used one.
Old 03-13-2008, 10:02 PM
Jawsgear's Avatar
We have mini spools available but you will need a standard carrier case. Lt me know if we can help you out.
Jeff
Old 03-13-2008, 10:51 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Jeff
Mini spools are not street legal! If you were to get into or cause an accident you would be sued and the company that supplied you the poduct could be held responsible as well.
I would look into a Detroit Locker if you are looking to be fully locked and drive on the streets.
Old 03-13-2008, 11:02 PM
RedLT4Mike's Avatar
You might get sued for your emissions illegal high output heads/cam modifications as well.
You should just stay stock with GM OEM replacement parts to be on the safe side.
Old 03-13-2008, 11:46 PM
DarkJuggalo's Avatar
u could always weld it and make it a spool
Old 03-14-2008, 12:58 AM
Texas_WS6's Avatar
No miny spools. I am looking for a True spool. I am not going to go to a 9" or 12 bolt at this time. I have my reasons. I do not wreck, so screw the law suit stuff. Just looking for a true spool/axle kit for a 02 F-body car.
Old 03-14-2008, 01:07 AM
97badass's Avatar
might be kinda newbish and sorry to highjack the thread but someone tell me why a spool is illegal.
Old 03-14-2008, 06:19 PM
There is no way they can prove it. Don't worry.
Old 03-15-2008, 12:47 AM
LOL. Yea....when was the last time there was a wreck, and the HP was like,...Hmmm maybe we better pull their cover and check for a spool huh?..
Old 03-15-2008, 01:06 AM
97badass's Avatar
ok that was a completely retarded answer to my question, maybe i should rephrase it so your marble can understand what im asking. why are you not supposed to use spools on the highway? what is so bad about them? there does that make more sense to you?
Old 03-16-2008, 12:03 PM
Texas_WS6's Avatar
I do not think there is a law on the or any books stating that spools are illegale for street use. But give a lawyer an excusse to blame you for something to make him money, I am sure he would. The reason that most spool manufactures say not for street use is mainly for their protection. Not that a spool will make you loose control, what it will do is it locks both the left and right tires together with no way that either can out run the other. Going around a turn, the outside tire has to travel more distance then the inside tire, which means it has to outrun the other. A spool will not let this hapin. SO there is alot of stress put on the tires, and the drive train. Stopping at a light and making a sharp turn might require some extra exceleration causing the tires to spin or at least cherp. Thats when the law will step in and acuse you of recless driving and ticket you. When you explain to him about the need to do that to turn because of the spool, he will not care and just give you the ticket. I for one am not worried about the law and tickets. I live in a small town and know most of them, of whom love cars, and will give me a pass.
Old 03-16-2008, 02:18 PM
9000th01ss's Avatar
If you've never driven a car with a spool you might be in for a few surprises.
It does lock the rear wheels together, this makes the car want to go straight around corners, if theres sand or anything in the road and the front tires slip you could lose it.
It also places a lot of stress on the axles, they are going to have a back and fourth twisting on them that will weaken them to some degree.
A mini spool inside a stock diff case puts stress on the case under hard acceleration, a full spool requires c-clip eliminators.
Just another way to torture the weak stock rear IMO.
Old 03-17-2008, 11:35 AM
97badass's Avatar
ok those are good explanations thanks guys.
Old 03-17-2008, 11:53 AM
RAGENZ28's Avatar
Save your money for the spool and put it towards a better rear end.
