12 bolt to 9" driveshaft question.
I have a strange 12 bolt in my car right now, and i'm getting a th400 setup from my friend who's running a 9" in his car.
We're both running a 1350 yolk. My question is will his driveshaft mating his th400 to his 9" fit when I put it in my car and try to mate it to my 12bolt?
length wise will be the issue. I think if anything it will need to be shortened, but I dont know....
little help please?
thanks!!
Jeremy
little help please?
thanks!!
Jeremy
little help please?
thanks!!
Jeremy
little help please?
thanks!!
Jeremy
My driveshaft is stock with a 443 conversion u joint and my LCA's are non adjustable. So how far the car is lowered takes a play also?
whats the best way to measure? just compare the two shafts?
is lenthening or shortening the shaft costly?
lastly... does the th400 change the driveshaft length? can you even use a stock length shaft th400 to stock rear / 12 botl?
thanks, big help.
Maybe i'll try the one he give me first though. How far should the splines be going into the trans?
I was hoping to just have it all ready to go once I got the motor in, but I guess its not that easy.
What do you guys normally do? pull a string across and then measure it?
