Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
I've read you don't need a tune for gears M6 car?
Old 03-29-2012, 06:57 PM
lazerlemonta's Avatar
Default I've read you don't need a tune for gears M6 car?
I really want gears for it bad. Talked to the service manager and as long as I don't flash the ecu the rest of the drivetrain will still be covered. Thanks for the help. I did a search and have read every post in this section hopping I wouldn't have to ask.
Old 03-30-2012, 12:16 PM
Gunslinger09's Avatar
The speedo will be off. Other than that you don't need a tune for it.
Old 05-15-2012, 04:02 PM
Higgs Boson's Avatar
The speedo will be off? Did they change the way the speedo works from all other F-bodies and vette's in 2010?
Old 05-15-2012, 05:26 PM
It's an electronic system. If you change the gear ratio without adjusting the computer the speedo will be off a little giving the wrong MPH reading.
Old 05-15-2012, 09:09 PM
Thanks guys. I was hoping to put 4.33s in soon but u guess it will wait
Old 05-16-2012, 04:24 AM
Never Satisfied's Avatar
FWIW, I have had 4.33's...3.70's...& now the 4.57 ratios in mine and it needed a recal each time. Good luck with those 4.33's. Mine lasted maybe 200 miles after the break-in.
Old 05-16-2012, 07:25 AM
yeah man i was thinking tire diameter, my bad.
Old 12-05-2012, 09:59 PM
badazz81z28's Avatar
Good lord! How does that ratio drive on the street?
Old 12-07-2012, 03:31 PM
Blackpanther99's Avatar
Yupp wont need a tune!
Old 12-07-2012, 04:03 PM
My guess is that he will be turning about 2200 RPMs at 70 in 6th gear.
Old 06-21-2013, 04:34 PM
Senetonix's Avatar
Like they said...just speedo off.
Old 07-10-2013, 02:08 PM
2012RedSS's Avatar
if the speedo reads off does it rack up mileage faster? I had mine tuned after the gear swap but I've always wondered that.
Old 07-15-2013, 04:47 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
the only cars that don't need the file edited for rear gear changes are m6 c5/c6's... all others need a file edit....
Quick Reply: I've read you don't need a tune for gears M6 car?
