Gen 5 Camaro Tuning, Diagnostics, Dyno results Tuning problems, solutions, dyno results for Gen 5 Camaro
2010 Camaro SS - Heads/cam results... So far
Old 05-31-2015, 08:23 PM
RealQuick's Avatar
Default 2010 Camaro SS - Heads/cam results... So far
2010 Camaro SS M6
Stock bottom end
AI 280cc Heads
vengeance racing turbo cam (235/231 .6xx/.6xx 115lsa)
.660 springs/pushrods/trunion upgrade
SLP under drive pulley
CAI CAI
Ebay 1 3/4" LT's
No cats
borla ATAK 2.5" exhaust
Tune via hptuners (me tuning)
Stock intake and stock TB
458rwhp/423rwtq ... I am going to do some more fine tuning.
Old 06-01-2015, 12:03 PM
Moderator
JasonShort's Avatar
Nice Jon! How are you liking the 5th gen now that you've had it for a little while?
Hope all is well with you and the family
Old 06-02-2015, 08:52 AM
RealQuick's Avatar
Jason, all is well! I miss the 96 T/A!
5th gen is awesome! Slow for the power... but an all around nice ride.
Old 09-16-2015, 09:01 PM
RealQuick's Avatar
I am hoping to hit the dyno two Saturdays from now with more tuning, NW 102mm TB and Radical 102mm Ported LS3 intake manifold.
Old 10-27-2015, 08:44 PM
RealQuick's Avatar
Dyno confirmed for this Friday (October 30th). Will be retuning with Peak Speed Radical 102mm ls3 intake and NW102 TB.
Old 11-12-2015, 12:33 AM
subeone's Avatar
Keep the thread updated to see what gains there are with the nick Williams and the radical ported intake. Been meaning to do this to my ls3 Vette but wasn't sure if there would be midrange gains.
Old 11-12-2015, 09:44 AM
RealQuick's Avatar
Unfortunately they didnt have my old run saved (so it could not be overlaid), but in the end I gained 3rwhp and lost 2rwtq peak. My WB wasnt matching up to theirs, so I eyeballed their numbers on the screen and tried to adjust my tune accordingly (hence why AFR was not a straight line). In the end I made 21 pulls ranging from 10.8AFR to 13.8AFR (seemed to like between 12.0-12.5AFR) and I tweaked timing from 17 degrees up to 25 degrees during tuning, I think it settled on 22 degrees if I recall.
Car made 458rwhp/423rwtq before the addition of the Peak Speed Radical 102 Intake and NW102 TB. After those two mods, new numbers were 461rwhp/421rwtq. Intake and TB didnt do anything for me, which leads me to believe they werent a restriction for me. I think the setup is just done in N/A form... big heads, turbo cam, small exhaust... i think it is just where it is.
A little disappointed as I wanted to hit 480rwhp... but the plan was always to turbo the car, and atleast I have a baseline before the turbo goes on this winter (Huron Speed/Precision 7675).
Attached Thumbnails 2010 Camaro SS - Heads/cam results... So far-dyno103015.jpg
Old 11-12-2015, 10:57 AM
ramairetransam's Avatar
the 1 3/4 headers and 2.5 exhaust cant help at that power. Some 1 7/8 would probably gain 10 hp .
Old 02-12-2016, 02:46 PM
RealQuick's Avatar
Update:
Car is back together with the addition of Huron Speed kit with Precision 7675, Alky Control progressive kit with AIS trunk mount tank, ADM FPRM, ZL1 Fuel pump, 95# injectors. I will re dyno in the spring.
Old 04-06-2016, 10:25 AM
Mrbowtie26's Avatar
Maybe the exhaust is hurting. I would think a 6 speed car with heads, cam, intake, exhaust would make a little more than 458. Still pretty good power but just seems like it should be closer to 480 ish.
Old 04-06-2016, 12:45 PM
RealQuick's Avatar
agree.
Car is back together with a 76mm Turbo... need to start street tuning when the salt on the roads is gone... then I'll redyno.
Jon
Old 05-06-2016, 12:21 PM
Phil'sC5vette's Avatar
Any fun updates with the new build.
Old 06-22-2016, 07:30 AM
1qwkSS's Avatar
i'd imagine with the snail it should be somewhere in the 730 range considering H/I/C
jon...wanna say you should see a considerable jump in power from that 1 3/4 to 1 7/8 just with bolt ons and cam only i did 465 tire on a HOT florida day...how you liking the TQ curve with the turbo on her?
Old 06-22-2016, 10:38 AM
RealQuick's Avatar
Thnx. I havent tuned it yet, so no test drives until I retune (hopefully in a few weeks).
Old 06-22-2016, 12:44 PM
its summer now , what the hell have you been doing sitting on your hands get that thing tuned.
Old 06-22-2016, 10:19 PM
RealQuick's Avatar
Lol, I know! Been super busy with work, family, and fabbing turbo kits for people. I'll get it going though, and post results (good or bad).
Old 08-23-2016, 12:04 PM
RealQuick's Avatar
Dyno time scheduled for 9/3
Updates to come!
Old 09-11-2016, 07:30 AM
RealQuick's Avatar
Dyno got shifted to yesterday. results:
Had an issue on the dyno with Ecu, bounced in and out of limp mode and was getting the p0606 code).
Called it quits at 608rwhp@10psi. Didn't want move timing up since I was getting this issue. I'll have to figure out the issue and go back.
Figured I would just post an update.
Old 10-22-2016, 07:48 AM
RealQuick's Avatar
Still having some issues... Won't make peak power above 5400rpm, but it still pulled 703rwhp/762rwtq
Quick Reply: 2010 Camaro SS - Heads/cam results... So far
