Can this block be repaired?
I recently bought a used ls1 shortblock to rebuild. It had a spun rod bearing. I figured I'd get the crank machined or replace it if needed, but then I found this when I stripped everything off of the block. It looks as if the engine spun a main bearing as well. Can this be repaired?
is it a bone stock block andy machine work done. stroker, bored ect
to have my block redone would be $2000 in machine work,
if it is bone stock get a new one dont even bother. machine work is alot. but if there machine work done to it i would see if it fixable
