what happened
what happened
so i got on it a little bit first and second gear and when i let off i heard a loud few thumps from right under me like someone took a sledge hammer to my undercarriage and it keeps doing this now if i downshift. any idea what this could be ?
Could be a failed transmission mount. Had one go bad on me once the tranny hits the top of the tunnel. Is your shift *** moving up and down? If so its the mount.
no shift **** is normal, ive been hearing smaller pops like this every know and then when i shift into gear for like a month
Tranny mount or torque arm mount. Could be both. Torque arm mount can look just fine till you take it off and flex with and mess the rubber. If it's bad, you'll see tears, split, most likely hidden as mine were. Although mine made it sound like something was smacking the rear end of the car. A bad tranny mount will make it sound like it's hitting right under the console, which it is.
LS1Tech Premium Sponsor
Sounds like it could be a transmission mount or torque arm mount. You should be able to jack the car up and visually check both mounts and see if there is an issue with them. If it is banging that hard it should be something pretty easy to find. If you run into anything crazy or have any questions you have my number.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
