Need advise finishing 408 Stroker build LQ4
What else do I need before having it tuned? What kind of Headers? What size injectors? What plugs?Anything else I'm missing?
1998 Red Z/28 SS Hardtop M6 w/ 6.0 LQ4 Block
TSP 408 Rotating Assembly
LS6 intake
LS7 hydraulic roller lifters
TSP LS6 Ported Oil pump
SLP
- Lunati Forged Crank and Rods
- ARP 2000 Bolts
- Wiseco -8cc Dish
- Clevite LS1 H Rod Bearing and H Main Bearing Set
- ARP LS1/LS2 Main Stud Kit
- Advertised Duration (Int/Exh): 267/273
- Duration @ .050 (Int/Exh): 217/223
- Gross Valve Lift (Int/Exh): .549"/.549"
- LSA/ICL: 113/109
- Valve Lash (Int/Exh): Hyd/Hyd
- RPM Range: 1800-6400
LS6 intake
SLP
- cold air intake
- Loud Mouth Exhaust
I understand that you want a stealthy sounding cam here, but you will be severly limiting the power output of that setup. Why not go with a better cam, and just tone down the lope with having the idle a tad higher from the tune, and setup the exhaust to drown out some of that chop from the cam then. Personally that's what i'd do if I was in your shoes
Steve Slavik @Lunati should find a new job. Call Martin Smallwood @Tick Performance for a custom cam thats not way to small. That cam would be considered a baby can for a 346 much less a 408.
On a big stroker like that, maybe something in the low 600 lift range, low 230 to low 240 duration, and maybe a 112-114 LSA. This is what I would choose...at bare minimum! You have to remember a larger cam in a bigger cubed motor will be more docile than that same cam in a smaller cubed motor. So basically what i'm saying is that you can run a much bigger cam than the one you have listed above, and still have great drivability and good low to midrange power, all because you have the cubes to offset the difference This is just my opinion of course...and like I said the tune and choice in exhaust can make a larger cam sound more tame if that's what you desire as well
Is a cam and spring swap something I could do myself in a couple days and about how long if I also do some LS6 heads? What else do I need before having it tuned? Your opinion on Headers? What size injectors? What plugs?
I don’t want to miss anything but I hate to put to much money into this car knowing that I’m thinking of buying a vette and it’s not a main driver.
Thanks,
Last but not least... Get a custom cam! Lol Call Martin @ Tick Performance.
