Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Camaro build
Old 04-12-2014, 10:52 AM
tbmb108's Avatar
Default Camaro build
Hey guys. Fairly new to the Lsx world. My brother and I decided to start a project. We are in the process of converting a 02 camaro to a drag car. Just thought I would post a thread to show progress and pick up some pointers along the way. As I siad before I am new to the ls platform. With that siad, constructive criticism is ok but please keep the negative comments. My brother and are are just looking to build a decent track car as inexpensive as we can and go out and have a blast.
Old 04-12-2014, 10:57 AM
HCI2000SS's Avatar
So what parts and mods are you looking at right now?
Old 04-12-2014, 10:59 AM
tbmb108's Avatar
We picked up a car from Craigslist for 600 bucks
Old 04-12-2014, 11:02 AM
tbmb108's Avatar
We pulled the ls1 out and 4 of the conecting rods were snapped, on of the rods poked a hole in the block under the motor mount. So we scrapped that and decided after a little research to do a 5.3 with a carb set up and MSD 6010 controller.
Old 04-12-2014, 11:04 AM
tbmb108's Avatar
We are going to use a comp cams I can't remember the grind right off hand. I think it is a 533/227 I will get the specs when I get home. We are going to run a 750 holley and a turbo 350 but trans. And replace the rear axle with a 8.8 ford with 410 ratio. We are taking the tourqe arm out and adding a turnbuckle style set up.
Old 04-12-2014, 11:11 AM
tbmb108's Avatar
This is the setup on the rear axle
Old 04-12-2014, 11:33 AM
tbmb108's Avatar
We finished our switch panel and gauge panel last night. I used a meter and found the wires I need to run the factory fog lamp switch for the ignition. And the car came with some kind of traction control so we are using that rocker switch for the momentary start switch.
Old 04-16-2014, 06:26 PM
tbmb108's Avatar
The intake came in last night. We are just using a old carb to do the mock up for cutting the cowl panel.
Old 04-16-2014, 06:28 PM
tbmb108's Avatar
MSD box awaiting engine install so we can find a good mounting place.
Old 04-19-2014, 02:32 PM
tbmb108's Avatar
Trimming out for the carb fitment
Old 04-19-2014, 02:34 PM
tbmb108's Avatar
All trimmed out
Old 04-19-2014, 02:37 PM
tbmb108's Avatar
Everything seems to fit ok. We have a few more trial run things to do and a little wiring to finish up and we should be shoving a cam and springs in the motor and installing it for good. We picked up a couple turbo 350 trans. We are gonna rebuild one for now to meet our needs and install it very soon.
Old 04-19-2014, 02:40 PM
tbmb108's Avatar
Old 04-20-2014, 11:34 AM
tbmb108's Avatar
Got some more of the wiring done last night.
Old 04-22-2014, 12:10 AM
tbmb108's Avatar
We got the shifter in and the original console trimmed out tonight. Stillness to hook up a few switches and we are good to go. We picked up a few th350's we are going to rebuild one with a stage 3 kit and a sprag tomorow night if anyone has any tips or hints on the rebuild please share.
Old 04-22-2014, 06:59 AM
spordee1's Avatar
Default Shifter
Cool shifter. Your brother and you really have your stuff together. Keep the good work up.
Old 04-22-2014, 11:29 PM
tbmb108's Avatar
Thanks the shifter took a little trimming and filing down but it came out pretty nice.
Old 04-22-2014, 11:31 PM
tbmb108's Avatar
We installed all of the z06 springs tonight (a first for me) cam should be going in tomorow if the shipping doesn't get delayed again.
Old 04-23-2014, 11:48 PM
tbmb108's Avatar
Engine is back together. New cam new springs new intake carb headers.
tbmb108's Avatar
And another
Quick Reply: Camaro build
