ls1 to lq9 swap
ls1 to lq9 swap
Okay so last summer I bought a 99 formula ws6 M6. After putting less than 500 miles on it the engine spun all 4 cam bearings and 2 rod bearings (I'm assuming they were all shot when I purchased)...dumso now I've decided to swap out the ls1 and swap in a used lq9 to get it running before summer returns. My question is what all do I need? I know I need the intake, oil pan with windage tray and pick up tube and all the accessories. Is there anything else? Pcm? Harness? Also need a new clutch and probably a fly wheel any thoughts there?
You can just use all of the parts from your LS1, and for a clutch I'd suggest a Monster level 2. If funds allow now would be a great time to swap in a mild cam, you'd want to keep it fairly mild due to the lower compression of the LQ9 but it would still be a nice bump in hp.
I know I need the intake - Yes
oil pan with windage tray - Yes
pick up tube - Yes
all the accessories - Yes
Is there anything else - Drilling the alternator bolt hole at the ear on the 6.0 M10 x 1.5 IIRC
Pcm - Same, just need a tune
Harness - Same
pick up tube - Yes
Harness - Same
LQ9 10.0:1
Not a huge difference.
LQ4 is 9.4:1.
The following users liked this post:
HWYKING (05-02-2023)
^^^Completely disagree with that. It has been proven that there are zero losses in low end torque on a stock LS1 using 1 7/8's header and a LQ9 wouldn't be any different. By using 1 3/4's headers now he would be limiting his hp gains from future mods like a cam, heads, boost, or n2o.
They wouldn't limit his cam selection but they would limit his hp gains from a cam. As for working around them, they're a 1/16th of an inch closer to the spark plugs, and at most a 1/4 inch closer to the starter. Why would you let those small differences in clearance limit future hp gains, it may just be a stock motor for now but maybe down the road it will have TrickFlow 235 heads and a FAST 102, then those 1 3/4 headers would be holding back 20+hp.
My 1 7/8's require a blanket for the starter. The blanket consumes all of the available space between the header and the starter.
To make it more maintenance friendly. This doesn't sound like a max effort build, but more of a street toy. I don't disagree that there's more power to be had, but if it's something that's not really a max effort setup, is it worth the extra grief to work around? By comparison, my buddy's WS6 is noticeably easier to work around with 1 3/4's.
Yeah this is nothing but a street toy to drive around. I plan on keeping the car for a long time. If there are any more mods other than headers it won't be for another 5 to 10 years so im not even thinking about it.
My next issue is tuning. Id like to do it myself with hptuners software. Does anyone have any experience with this or know how tricky it is??
