General LSX Automobile Discussion Non-technical LSX related topics.
Borla exhaust and bbk long tubes ???
Old 03-07-2015, 05:40 PM
z06 hellcat's Avatar
Default Borla exhaust and bbk long tubes ???
I have borla exhaust on my 99 ws6 and I installed bbk longtubes and y pipe, now the exhaust is a lot louder on the passenger side, is this normal?
Old 03-07-2015, 06:44 PM
98z8uup's Avatar
Do you have the adjustable borla kit? If so do you have the plates out.
Old 03-07-2015, 07:47 PM
scotty2000ss's Avatar
If you have the adjustable borla, put a cut out on the side where the plates go. Check the sound clip in my sig. That's what I did.
Old 03-07-2015, 07:49 PM
Not sure, I bought the car with it, how do I know if it's adjustable or not?
Old 03-07-2015, 08:00 PM
Plates go in the passenger tail pipe. 4 to choose from.
Old 03-07-2015, 08:03 PM
My system looks the same as the picture but no plates.
Old 03-07-2015, 08:06 PM
That's the beauty of that system. No plate is like having no muffler lol
Old 03-07-2015, 08:37 PM
Thanks for your help guys!😚
Old 03-07-2015, 11:43 PM
Deeohgie69's Avatar
I had the same problem with mine man, it was pull me over loud. You can make your own plates with some tin snips and some thin sheet aluminum. I bought mine at lowes and found that a 3/4" hole sounded about the best with my cam and no cats. You can make at least 8 plates from the one little sheet so you should be able to find the perfect tone you want. Once you take off the 3 bolts holding your tailpipe on you will see it already has a fully open plate that you can use as a template to cut your new ones.
Quick Reply: Borla exhaust and bbk long tubes ???
