safe to drive?
safe to drive?
i just put full exhaust on and without having the rear 02 sensors will it hurt or starve the motor? im getting it tuned soon so if it will starve it then i just wont drive it till then
Internet Mechanic
If the 02 sensors are not reading anything, be careful. Usueally the reason why the SES kicks is the reading from the Upstream (before the cat) and down stream (after the cat) o2 sensor and there is a bigger difference then the stock tuned pcm will allow. But no reading could make it even worse.
I personally ran cats and vetter rear 02's in the front and never got a code.
You're not gonna hurt anything running without the rear O2s. The only thing that could happen is if something else goes wrong, you won't know it because your SES light is already on.
