General LSX Automobile Discussion Non-technical LSX related topics.
New Engine?
Old 05-13-2008, 11:49 AM
tbonebuggs's Avatar
Default New Engine?
Right now I drive a partially modded 2000 V6 Camaro, but would like to add some serious power. I am planning on purchasing a new engine but I am not sure what else I'll need to buy when dropping in a new engine. I plan on getting some type of V8 engine, probably a stock from a LS7 corvette or a SS camaro.
Old 05-13-2008, 11:56 AM
dragonrage's Avatar
A transmission and rear-end that will be able to handle the power. 4L60E, T5, and the 10-bolt are not good enough unless you're going to baby it (in which case why would you be buying it?). You'll need a new computer and wiring harness as well.
Not sure what else.
Old 05-13-2008, 12:06 PM
SickkSS01's Avatar
Well, putting an LS7 will require a large amount of modification in order to work because of its oil system (dry sump). You're better sticking with an LS1 or LS2 and going from there. However, if I were you, I would just sell your V6 and get an LS1 powered fbody. It will be a lot cheaper in the long run and you won't have to worry about all the parts and stuff. My insurance went up $12/month when I went from my 2000 Camaro V6 to my 2001 Camaro SS.
Old 05-13-2008, 12:10 PM
dragonrage's Avatar
Well, depends on how much power he's looking for. I'd much rather start with a bigger engine if I were looking for much more power than an LS1. And he'd need to replace the 10-bolt even if he modded an LS1 Camaro. T56 would be fine if he got one of those, though. Computer/wiring stuff would probably be much easier that way.
I dunno, though; depends on what kind of power he's looking for.
Old 05-13-2008, 12:12 PM
tbonebuggs's Avatar
Selling my car is not an option at this time. Would it be cheaper to drop in a supercharger/turbo setup?
Old 05-13-2008, 01:14 PM
hllrzrls1's Avatar
if money's no object then gmperformanceparts.com is where you need to be also depends whether you want a maual or an auto but one universal is that a 10 bolt wont cut it id recommend getting a bolt in 9 inch but if LS1 style power is what you want trade in for an LS1
Old 05-13-2008, 01:58 PM
dragonrage's Avatar
No, don't bother with forced induction on the V6. Upgrading to a V8 is a better option.
Old 05-13-2008, 08:08 PM
z28bryan02's Avatar
Have you priced out an ls7 motor its not cheap, and good luck finding a new z06 in the junk yards
Old 05-13-2008, 08:16 PM
dragonrage's Avatar
Could grab an LS2 and build it up though
Old 05-13-2008, 08:18 PM
tbonebuggs's Avatar
I'll probably just go with an LS1.
Old 05-13-2008, 08:55 PM
CT15's Avatar
I'd stick with an LS1/2/6. I think the 7's are around $15-20K and the labor would kill you. Or you could just get a new car and sell the V6.
Old 05-13-2008, 11:42 PM
ads_99ta's Avatar
first, how much are you willing to spend? there are semi-affordable 402/408 crate engines that can almost triple the hp you V6 currently has. thats probably the best way to add serious power like you said you wanted. but that also will eventually drivetrain modifications.
