quick question
Old 10-21-2008, 03:02 PM
EliteCamaro94's Avatar
Default quick question
Hey guys i got a quick question, i dunno if this is the right spot to put this but mods move it if need be. So my question is this, i have a 1994 z28 and when i have to stop quickly my sunvisors swing forward and hit the front windshield everytime. Then i have to slide them back and its getting annoying. Does anyone know how to stop them from doing this do i have to buy new visors??? if so where do i get them?
Old 10-21-2008, 09:45 PM
joshp14's Avatar
The rod that allows it to pivot slides into a sleeve. If the sleeve is loose or worn you will have this problem. Most of the time you cant fix it and it will require new visors.
Old 10-22-2008, 09:11 AM
do you know where to get the new visors?? do i just have to get them at a dealer or is there a cheaper alternative? thanks for the response
Old 10-23-2008, 01:53 AM
ZexGX's Avatar
Wrong... 99% sure it's just a spring that you need to replace.
Here's a few quick links to read up on:
https://ls1tech.com/forums/showpost....65&postcount=8
https://ls1tech.com/forums/showpost....25&postcount=9
Old 10-23-2008, 10:50 AM
are the visor set ups the same in the ls1 cars as they are in the lt1 cars? im sure they are but i just wanna make sure before i try and attempt this stuff.
Old 10-23-2008, 07:13 PM
ZexGX's Avatar
Just go for it. Worst thing that could happen is you have to bolt the triangles back in without sunvisors until you buy new ones.
Old 10-24-2008, 01:09 PM
well does anyone know where i can buy new ones other than at the dealer? i guess i could check the junk yards but they would be hit or miss too and kinda a waste time.
Old 10-25-2008, 07:17 PM
ZexGX's Avatar
GM parts direct (google it) for new parts, or just hit up people parting out cars here on Tech. I may be able to find some locally and ship but I will let you know.
Old 10-25-2008, 07:39 PM
ae13291's Avatar
i did that mod, works well my dad just had to re tap the aluminum to accept a screw rather then a rivet
