Quick online diagnosis before taking it in..
Ok, before I take it in to a local mechanic I wanted to see if this forum's community could help me pinpoint the problem I'm having with my T/A.
I have a 99 T/A AT with 79,000 miles.
There seems to be some clunking noise coming from under the car when I put it in reverse from park. It occurs as it shifts, and its not a deep clunking noise its more like taking two thin pieces of aluminum and taping them together real quick. I think it even occurs when going from reverse to drive but the sound of my exhaust makes it hard to hear.
Also, when I'm cruising at about 20-30 mph and rev it there is a chirping noise that comes from under the front of my car. I can only hear this chirping noise when its rev'd and only at low speeds. I think it happens at higher speeds I just can't hear it. The chirping noise only happens right after the engine is rev'd. I step on the pedal, then there is a moment of lag in which the chirping occurs, then the engine picks up. The lack of response from pedal to engine is pretty long as well. Its like having a 56k modem again but applied to my pedal/engine.
I plan on bringing it in to a local mechanic (not a dealership) to have them look at it but I wanted to get some advice before I bring it in. Last thing I want is for them to fix something that doesn't need to be fixed and still have these issues. Any help would be much appreciated.
I'm not very savvy when it comes to vehicle mechanics...its not really a clunk more than it is a tink tink kind of sound...a light tapping so to speak...and I can only hear it when shifting from park to reverse that initial jerk comes with that tinking sound...
Yeah it could be fine but this isn't a loud solid clunk. There is a clunk when the gear is shifted which I assume to be normal but there is metal tapping sounds. Tink tink tinktink kinda sounds that come from under the car.
I just wanted to get some ideas before taking it in to the shop.
could be the u-joints on your driveshaft, because it does this front forward to reverse and vise versa i would think its something thats moving ie driveshaft or rear end and the u-joints connect these together.
The symptoms you are describing kind of sounds like a cracked flexplate. Is it the belt chirping? If you take the belt off and rev it is the noise still present? (dont run it longer than 20 seconds with belt off)
As far as the clunk between drive and park and reverse, some is normal as all of the gear backlash is being taken up when going between gears. If you think its excessive, it may be a slip yoke, driveshaft, or u-joint problem.
[QUOTE=joshp14;10342520]is the belt chirping? If you take the belt off and rev it is the noise still present? (dont run it longer than 20 seconds with belt off)QUOTE]
The belt was changed less than 4000 miles ago.
The chirping does not happen when the car is in neutral. It only "chirps" in gear when I am cruising, foot off the gas, at 25-35 mph and then punch the gas real quick. As I punch the gas, there is a quick chirping sound coming from under the engine, as the car accelerates but quickly goes away. If I continuously punch the gas over and over at this speed it continuously chirps...gas chirp gas chirp gas chirp...Over the last six months it has progressivly grown louder and more prominant.
