Window motor help!!
Old 09-28-2009, 07:57 PM
THE-ZCamaro99's Avatar
Default Window motor help!!
Okay so my windows have been getting slower and slower and now my driver side will go up almost all the way and stop. I'll wait a few seconds and then try it again and it will go up maybe and inch, then i just have to keep doing that till its all the way up. Now my passenger one is doing the same thing. Does this mean they are done or do you think it is something else? Also, how hard is it to replace them? I have had my door panels off before and it want too bad but there wasn't really anywhere to get my hand in the door. Oh and where would you guys recommend getting a new one from.
Old 09-28-2009, 08:08 PM
therealcreeper's Avatar
they're dead. buy 2 new ones and the passenger window re-wiring kit. autotrix or someone makes it. i have 1 ebay $20 one and one autoparts store $50 one. they both work fine. ebay one is a tad slower though.
install isn't bad. drill 3 holes through the fiberglass to access the studs. then drill out the studs. take out the speaker so you can get your hand behind there to unplug it and pull it out. bolt new one in and you're done. takes about an hour for the first door, half hour for the next once you get the hang of it.
Old 09-28-2009, 10:12 PM
00_Z-28's Avatar
replace it i just did mine this weekend and it was super easy! took 2 hours tops. Your window is deffently going out and if you have already taken you'r door pannel out than you will have no problem at all ill look for the link to the site with step by step instructions.
Old 09-28-2009, 10:16 PM
00_Z-28's Avatar
http://shbox.com/page/windowmotor.html
Old 09-28-2009, 10:39 PM
Thanks guys, looks like i got my weekend project.
Old 09-28-2009, 11:22 PM
bballr4567's Avatar
If ya need some help, Im open. Ive done the passenger side window fix and its faster than the driver side window. Id do the driver side one but Im quite not up to wanting to do another one yet. Ill probably do it next spring.
Old 09-29-2009, 08:17 AM
niceguyyy01's Avatar
Yep. I gotta do this too.
Old 09-29-2009, 12:22 PM
hopefully i'll get to it tonight, i have class 1-5 then comming home and start tearing it down. My brother said he would help if i need it but im sure i can do it myself. Thanks for the offer though
Old 09-29-2009, 07:42 PM
well i got my driver side window motor in, it only took my about an hour and a half. Gotta run out to the other side of town to get the pass side one maybe tonight
Old 09-29-2009, 07:57 PM
tripps's Avatar
Buy 2 new motors, and replace them yourself. they are really easy to do.
Old 09-29-2009, 09:07 PM
HVAC-Tech's Avatar
like stated, go to the autoparts store and buy new ones. I need to replace my passenger side motor to.
Old 09-29-2009, 11:33 PM
welp im done, there are a few things i need to check out but i got them in and the are going up and down. My pass side motor clunks when it is all the way up and i start to roll it down and when its all the way down and i start to roll it up. Also i have no idea how it happened but on my driver side switch, down is up and up is down. I have no idea how this happened because the only wires i unpluged was the one on top of the window motor. I'm just going to live with it though for now
