Oil Pressure and one other question.
Old 10-15-2009, 06:59 PM
Endersshadow's Avatar
Default Oil Pressure and one other question.
I have a 94 Formula. I was wondering if the oil pressure seen in the picture below is normal? I was stopped at a light and my engine was plenty warm as you can see.
Also...one other thing. I removed the intake silencer and replaced it with a V05 bottle. I was wondering if this is ok or not? It was my friends idea and he said it should be fine...but I'm skeptical.
Old 10-15-2009, 07:47 PM
LS6427's Avatar
Oil pressures can drop that low at idle when you're that hot. Its just a guage...doesn't mean its accurate.
The V05 bottle thing.....I have no idea.
Old 10-15-2009, 08:54 PM
cherryelky305's Avatar
is the v05 bottle a joke? lol......why not just put the silencer back on?
Old 10-15-2009, 09:20 PM
My car actually seems to run better with the shampoo bottle. lol.
Old 10-15-2009, 09:25 PM
LS6427's Avatar
What does that shampoo bottle actually do?
Does air get sucked into it and then into the engine? please say NO
Is there a filter on it? please say YES then
Old 10-15-2009, 09:46 PM
From what I can tell it just stops the air from going down into where the silencer used to be.
Old 10-15-2009, 10:04 PM
fleetmgr's Avatar
If you start seeing bubbles in your mirror, run.
Old 10-15-2009, 10:06 PM
hahaha. I cleaned it out thoroughly smart ***!
Old 10-15-2009, 10:08 PM
LS6427's Avatar
I was gonna say...if air can enter there and go into the engine its unmetered air. So you will run a little lean, which will give you more power, which will kill your pistons.\
So its just plugging up that opening??? Couldn't you get something smaller that looks better. How about cutting the bottle down so its even with the black plastic.
Old 10-15-2009, 10:12 PM
I didn't see the sense in making it look good if I found out it was going to hurt my car in the long run. But yeah....I could easily cut it down and make it look much better.
Old 10-15-2009, 10:13 PM
I think this will give you some better gains
Its dependable, people have been using them for years. especially in Pro Modified.
If you have money to burn try importing one of these, all of Europe's best use them for a massive power gain.
all in good fun, but seriously figure out the real issue and fix it, dont stoop to duck tape and wd-40 fixes.
Old 10-16-2009, 12:54 AM
Thanks for not helping. I just wanted to know if having the silencer off and the bottle in it's place will hurt my car.
