Does differential fluid smell linger??
Old 01-13-2010, 06:35 PM
NC01TA's Avatar
Default Does differential fluid smell linger??
First time I ever had the differential fluid changed ('01 Trans Am)and the fluid smell really stinks. Can anyone advise me if the stink lingers for awhile, like days maybe?? I checked real close for any leaks or residue after the job was done but everything is bone dry. My garage just reeked the first night after it was done. It was the Delco 75-90 synthetic that was used. Thanks in advance if anyone has a similar experience or can let me know.
Old 01-13-2010, 08:20 PM
1 FMF's Avatar
yes it'll linger if its in an enclosed area.
air it out for a few hours per day or febreeze the garage,
if you had the diff. oil changed then drove it right home and parked it then i'm not surprised it stinks. If you drive the car a couple days the smell will wear off faster.
Old 01-13-2010, 08:45 PM
slayer_taunu's Avatar
yeah that gear oil real does stink. i like the smell of most automotive fluids... but gear oil, no thanks.
it'll go away eventually.
Old 01-14-2010, 02:24 AM
myk
myk's Avatar
'Diff oil reeks and is generally gross-very fishy and hard to get rid of the smell, especially off of your fingers. If anyone asks about the smell, just say you went on a hot date the night before...
Old 01-14-2010, 07:53 AM
NC01TA's Avatar
Thanks very much for the replies. It is appreciated. I am guilty of doing just that; driving from the shop right into my garage.
Old 01-14-2010, 08:50 AM
slow96z's Avatar
Nice. Mike, if your "hot dates" smell like gear oil you are either dating pit techs from Jiffy Lube or need to rethink your selection of ladies!
Unless, of course, they look like the one in your sig, then a little gear oil smell is acceptable.
Old 01-15-2010, 08:40 AM
samson_420's Avatar
LMAO. . . . .
Every time I change my diff fluid it kind of makes me wanna hurl. . . 90 Weight sure does have a strange stink to it.
Old 01-15-2010, 10:30 AM
nascarnut08's Avatar
Try changing a ford diff with friction modifier. Really nasty!
Old 01-15-2010, 10:39 AM
pillarpod's Avatar
gotta love of the smell of differential fluid in the morning. It wakes you right up
Old 01-15-2010, 06:09 PM
NC01TA's Avatar
The smell is indeed fading away and I figure another 2 days and it will be gone completely. This is one time I should have left the car outside. Next time I will know. Thanks again for the help.
Quick Reply: Does differential fluid smell linger??
