dont know whats going on....
Old 01-26-2010, 04:17 AM
f-bodyguy's Avatar
Default dont know whats going on....
so i at whits end with my car. nothing is wroking right...when the cars running all my sensors are going hay wire...my maf,iat,map,cam,and im sure something elseit all started after the cam swap...i had a 6.0 done and it had been in the car for about 2 months before i installed the cam...i dont know what to do i want to get the car tuned could it be the ecu? or a ground? or the harness? i dont know what else it can be..i have a friend thats going to let me use his stock ecu to try...but i dont know when...any one help please
Old 01-26-2010, 05:16 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Im going to move this to the maintenance area. You may get faster luck there. Sounds wiring related thats for sure.
Old 01-26-2010, 07:23 AM
CamdLS1'00SS's Avatar
id reccomend a tuning on the stock 6.0 litre ECU, stat
Old 01-26-2010, 01:10 PM
f-bodyguy's Avatar
cant tune till i get everything worked out....because everthig is all screwed up
Old 01-26-2010, 01:41 PM
eseibel67's Avatar
It ran fine before the cam swap, correct?
Yes it could be the PCM, but not likely. Why would the PCM crap out just because you changed the cam?
First I would check the ENG SEN fuse.
Then I would check the grounds.
When everything wigs out at once, it has to be related.
Also, is this a wild cam? Not sure that in itself could cause your problems.
Old 01-26-2010, 05:56 PM
f-bodyguy's Avatar
nothing crazy its 230/227 .595.575 112lsa ....so i did find out that i had 2 plugs that had cracks in them...that explains the missing and backfires, but doesnt explain the constant voltage chage in my maf(11.5-6 to 3.xx) and, im getting cam sensor high voltage output,
Old 01-26-2010, 06:59 PM
possibility the maf and the cam sensor went bad? thats too easy of an answer though...on your block is the cam sensor on top up front of the motor or is it around the back?...if its up front does the maf and the cam sensor come from the same harness? maybe a couple wires got damaged and are shorting which would explain the surging voltage in the maf and the high output from the cam sensor.
Old 01-26-2010, 07:15 PM
f-bodyguy's Avatar
well i have replaced the cam sensor and the pig tail...and swapped maf with a friend ....and its around back and they are on the same harness....i have the intake off the car right now and am looking throught the wires and trying to find an exposed wire or a loose ground... and and all comments appreciated thanks
