Car wont start, any help?
Old 03-24-2010, 10:04 PM
KuruptedWS6's Avatar
Default Car wont start, any help?
car has been sitting for around 2-3 months, the ac delco battery was dead and a few years old, replaced it with new battery and car still wont start, wont crank, nothing, dead silent. checked some of the fuses and look ok to me. not sure what to look for if they were bad though. its a 2001 trans am. anything else i should be looking at?
thanks for any help.
Old 03-24-2010, 10:10 PM
lvbroham1's Avatar
clean the vat device in your key. Or, check battery cables for corrosion. Could be that it was sitting for so long the cables corroded.
Old 03-24-2010, 10:11 PM
lvbroham1's Avatar
sorry, I thought it said 2-3 years. Cables shouldn't be corroded that soon. Start with the vats.
Old 03-24-2010, 10:12 PM
LS1vazquez's Avatar
Check your relays, the big grey box looking things in your fuse box. Start swapping them around.
You might have accidentally blown the starter relay when the battery went dead.
Old 03-24-2010, 10:51 PM
thanks for the tips, i will check the relays tomorrow and update the thread, thanks!
Old 03-25-2010, 05:56 PM
tried new relays today and still nothing.
Old 03-25-2010, 09:47 PM
lt1pwr1's Avatar
Have you checked for power at the starter when you turn the key to start? If you don't have power there I would check the neutral safety switch or clutch safety switch (if manual trans). If you don't have power to those you could have an issue with your ignition switch.
Old 03-25-2010, 10:01 PM
bigj2717's Avatar
Does the security light come on? If so its a problem with the VATS and you can just bypass it to get it to start
http://shbox.com/1/vats_bypass.jpg
Old 03-25-2010, 10:40 PM
its an auto, after listening closely i can hear 2 light ticks when i turn the key.
the security light does not light up.
Old 03-27-2010, 05:24 PM
ok, so yesterday morning i opened the hood to find a possum sitting on the engine, how it crawled up in there i have no idea, but after looking around i found this disconnected,, couldn't find where this hooked up to, not sure if this is why the car wont start but im sure it could help
Old 03-27-2010, 05:55 PM
Taken4granted's Avatar
check the surrounding areas if any wires are chewed
Old 03-27-2010, 06:34 PM
lt1pwr1's Avatar
Haha that was gonna be my next guess because it happened to me before. Always put moth ***** around the car and in the engine bay if it is going to sit. It will keep the critters away. Mine only sat for 2.5 weeks and it was in a garage and I had wires chewed up. That can be a very big headache for you unfortunately. Best of luck.
Old 03-27-2010, 07:19 PM
more pics, i dont think roddents chewed these, doesnt look like it anyway. wtf
Old 03-27-2010, 10:24 PM
is that your AIR system?
Old 03-27-2010, 11:39 PM
its the bigger hose thats runs along the driver side of the car, better pic here
and on the passenger side here.
Old 03-27-2010, 11:53 PM
the big one that comes from the driver headlight and runs along the driver fender to the back of the motor is the AIR tube. it looks like it was removed. in that case you should have block off plates on your exhaust. the one on your passenger side connects to your intake manifold, right below and slightly to the left( I can see where it connects upper right hand corner behind the TB cable but in front of the coolent line)
looking at the picture
Old 03-28-2010, 12:08 AM
here?
Old 03-28-2010, 12:53 AM
yes right there
Old 03-28-2010, 01:10 AM
yes right there
thanks, any idea about this one?
