TA Headlights possessed by satan
I have a 97 TA. Today, my headlights started acting strange. When I lock my car with remote, the headlights pop up then go back down, then it makes a terrible grinding noise. It seems the right headlight motor is making the noise. Then, when I turn on my lights one click (foglights only) the headlights come up too. THen when it closes, it makes grinding noises again. ANy ideas?
your headlight motor/gear has gone bad either replace the motor or the plastic gear inside the motor (with a metal one). Your headlights will return to normal and the grinding will stop... I recommend going to autozone and picking up a reman or aftermarket one for 100 bucks as they come with a lifetime wty
My old '96 Formula did that too and the above advice is correct. Hopefully you can find someone to do it for you if you can't do it yourself. The dealership quoted me $300 for that repair but fortunately I found a car guy that changed it out for me for $50 plus the part(s). Whew!
you don't have to replace it, only half the gear is used to open and close the headlight. So just pull it out and use the other half of the gear
link to help you
https://ls1tech.com/forums/pontiac-f...s-go-here.html
link to help you
I just did this, given my car is a 02... But un hook the linkage from the motor, then use the manual **** to roll the motor 180 degrees and hook the linkage back up. Should take you 5 min to do as it did me and ive had no issues at all.
one side is slipping and one isnt so it kinda freaks out i guess. mine did the same thing when the gear was stripped. i tried the temp fix, but it was stripped too far around. went ahead and replaced both with the metal gears and havent had a problem since. i would definately get those instead of another motor with the plastic gear. i think the metal gears are about 40 each, but not positive
I seen this vid on youtube showing what was mentioned above on using the other side of the gear instead of replacing it. check it out, give it a shot.. http://www.youtube.com/watch?v=HuolISwRJJg
The lights freak out because the gear slips.Thats it. There is a thread specifically on headlights, but you need new gears. The 180 fix doesnt work for long and then you'll be back under the hood working on it again. So go ahead and knock out your problems by replacing the crappy plastic gears with metal ones.
http://www.bfranker.badz28.com/headlightfix/
Also, check the rubber stopper at the linkage that stops the headlight in the up and down postions.
