~ Lots of U and C codes! Need direction ~
Old 05-12-2010, 12:42 PM
nimrod.sixty9's Avatar
Default ~ Lots of U and C codes! Need direction ~
[Brake] C0896 - Device Voltage Range/Performance (History)
[Brake] C0550 - ECU Malfunction (Current)
[Brake] U1000 - Class 2 Communication Malfunction (Current)
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[Restraints] U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
[HUD] U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
[HUD] U1000 - Class 2 Communication Malfunction (History) (Immature)
These were pulled with HPT (thanks Tom!)
I do have other issues as well:
https://ls1tech.com/forums/general-m...abs-brake.html
https://ls1tech.com/forums/general-m...lant-help.html
Sorry if there is something obvious here, but Im completely a noob to this stuff. TIA
Old 05-13-2010, 09:35 AM
Which one is the EBCM? 1 or 2 OR 1 and 2?
Old 05-13-2010, 11:44 AM
theguyulove2hate's Avatar
The EBCM is 2, but you have to buy 1 and 2 together I believe. Its really expensive, I think it is around 800 if not more.
Old 05-13-2010, 12:31 PM
I still need to check connections, but Im guessing it is toast. Ill most likely eBay it like everything else LOL. Im hopeing to avoid pulling the whole thing as Id have to bleed the system with a tech 2.. correct?
Old 05-13-2010, 12:32 PM
myk
myk's Avatar
If you're chasing ABS INOP/LOW TRAC/ASR OFF problems it could be your wheel sensors, like we talked about in the other thread...
Old 05-13-2010, 01:30 PM
Wouldnt I have a code for the wheel sensor if that was the case?
Old 05-14-2010, 09:02 AM
Ttt :d
Old 05-17-2010, 12:01 AM
I have never used a Tech 2 to bleed my brakes. Just a thought, you could have a mess up exctier ring. I dont see that happening but who knows
Old 05-17-2010, 04:35 AM
Alt was replaced today. Couldn't wait any longer, it completely died out.
Fixed all the flickering light issues and its charging great.
But now my service vehicle light came on (along with all the other lights). It didnt come on immediately after the install but it did happen today... Wth is that about?
Old 06-20-2010, 06:18 PM
Looking at replacing my ABS unit soon. How would I go about bleeding?
I do have a mityvac...
Quick Reply: ~ Lots of U and C codes! Need direction ~
