Power steering reservoir pressurizes, leak somewhere
Old 08-10-2010, 06:22 PM
Vetal's Avatar
Default Power steering reservoir pressurizes, leak somewhere
Please help me with this problem... I have PS system leaking. It was leaking at the line in the side of the reservoir. I've replaced the line, now it leaks somewhere else. Local garage said that is because fluid is overheating (I have turbo and truck manifolds there). Is that possible? Also is this right that when I remove the cap from the reservoir, there's a lot of pressure inside? Is this because of fluid being heated?
What should I do?
Old 08-11-2010, 02:22 AM
Vetal's Avatar
anyone? is it normal for the PS system to build up pressure in reservoir?
Old 08-11-2010, 06:01 AM
Save the manuals!
wssix99's Avatar
yes, all above is correct. This is a common problem, even for folks with a stock setup.
So far the options I've seen are to get a TurnOne racing pump (may not be good for a lot of city driving) or put on a different PS cooler. I'm trying a Permacool frame rail cooler now and should have a verdict in a couple of weeks.
Old 08-11-2010, 06:14 AM
Vetal's Avatar
where does it usually leak from? is it from heat, bad pump design, or bad (not holding pressure) system alltogether?
Old 08-12-2010, 09:30 AM
Save the manuals!
wssix99's Avatar
Well, if DD's have problems then I'd say its either:
- a bad overall system design
- an issue that only comes up when the PS fluid starts to get old
This article has some great insight. http://www.gmhightechperformance.com...all/index.html
There is always a design trade off here. Performance at slow engine speed vs. heat and over pumping. From a racing and highway perspective, the pump is overpowered. If you drive a lot in the city, then the stock design has a lot of merit.
Old 08-12-2010, 09:57 AM
Vetal's Avatar
don't see actually any bad about design only that it's all unwrapped. and I think even stock LS1's happen to have problems with leaking PS
Old 08-12-2010, 10:21 PM
97ramsst's Avatar
Do you have a PS cooler on your upper radiator hose?
Old 08-13-2010, 01:47 AM
Vetal's Avatar
no .
Old 08-13-2010, 08:49 AM
HotSilverBird's Avatar
You need it, get one and your fliud will stop boiling out. I had the same trouble with mine, was always wet around the cap.
Old 08-13-2010, 08:58 AM
Vetal's Avatar
I'll see how much I can reduce underhood temps first it will be great overall anyway
Old 08-13-2010, 09:50 AM
97ramsst's Avatar
Actually, I was going to say if he did to ditch it because thats the culprit. They are notorious of leaking internaly and letting coolant pollute the PS fluid causing it boil over.
Old 08-14-2010, 12:49 AM
Save the manuals!
wssix99's Avatar
I even had this problem with a stock cooler. I just switched to a 24" Perma-Cool frame rail cooler that I mounted just behind the front spoiler. http://www.perma-cool.com/Catalog/Cat_page15.html Praying that this does better... We'll see in a couple of weeks.
Old 10-18-2010, 12:05 PM
Save the manuals!
wssix99's Avatar
My aftermarket cooler looks to be a success: https://ls1tech.com/forums/general-m...l#post14005563
Quick Reply: Power steering reservoir pressurizes, leak somewhere
