Brake hose swap?
I just bought new metal lines all around.
I'm also putting in a performance fluid, so I'll be flushing my entire system thoroughly. After I remove the lines and all the fluid (or most of it) drains out in that process, then after I put the new lines back on..........Sam Strano told me to fill the brake fluid master cylinder, then bleed the rear-right, then the rear-left, then front-right, then front-left.
So wait at each brake for the new fluid to come out...easy to see the new clean fluid. And have a friend there to keep topping it off between and during hitting each brake to bleed/flush it.
My question is, when i'm replacing the lines won't most of the fluid come out?
I just re-read his email. He said to start by sucking as much of the old fluid out of the master cylinder.......then top it back off with the new fluid. Then bleed/flush it through in the pattern above.........and DO NOT allow the master cylinder to run dry while doing the bleed/flushing at all corners.
Or, do we go ahead and suck it dry, then top it off, then while we're changing the lines do I need someone there to keep topping it off with new fluid as it dribbles out of each line?
