lost power!
lost power!
I was driving one morning and i wanted to pass a car. So i stepped on it a little, when i did this the car accelerated then all of a sudden it let off on its on, still accelerating but with less force (lost power). AFter the car has been feeling weird.
When i turn the car on it idles lower than what it should be. When i drive it almost wants to die. When i put it into reverse it dies(a4).
I think it might be a cylinder not firing. i replaced all the coil packs and spark plugs along with new wires. and still no change.
The only codes im getting is missfire codes. at idle and light acceleration.
Car is cammed a4 stalled. I dumb founded. Im gonna try to clean the maf and see what goes on.
the problem is while at idle and driving. i didnt check while driving since its a mechanical gauge i need to leave it there.
im gonna clean maf tomorrow. ill see how it runs.
maf was cleaned again and the cp sensor was replaced. felt like it was running betting but this afternoon same ole story.
its good to note that at the same time this happened the car developed a howling sound and it follows the rpm either in park or in D.
i think they are related but i cant pinpoint the problem. I'm gonna try to change the tranny fluid along with the filter.
Anyone else have any suggestions?
please note i also changed the fuel injectors.
i resealed the fast intake.
just to be sure. i fired her up and still the same. i checked for vac leaks and nothing. i used the starter fluid method and spraying around.
when you changed the plugs were they dark and dirty or kind of white and chalky? im sure they werent white because if they were it would be your injectors thats the problem but since you changed the injectors and still the same problem it could be the coil springs causing the plugs to turn black.
I'm assuming you don't have a scanner to read live data? Man, you sure sunk alot of money into your car "hoping" to fix it. Without a good scanner, you really are just playing guessing games and wasting money in many situations. Don't take offense to that, but sometimes you are better off just taking it to a shop in the first place unless you have extra parts laying around to test. If you can get a good scanner on it I would look at the o2 data and make sure they are switching correctly.
Also, if your MAF is actually bad, you can do all the cleaning in the world and it won't fix it. You could be chasing your tail with that as well. Try to get a known good MAF and swap yours out to see if it fixes the problem.
no offense taken.
lmao i do have efi live and with a road runner pcm so i can real time tunning.
there is no codes for maf or tranny related. i did change my coil packs as well with some accel d585s truck style packs. same issue.
half the parts that ive changed i had laying around. really was only the rails and injectors i had to buy which set me back about 120 together or so. so im good.
but do you guys still think its the maf? even though i have no codes?
Now, would I go out and buy a new one at this point? No, (unless you can return it if it doesn't work) but I would try to first get a good used one from a friend or somebody who has an Fbody. That is really the cheapest way of figuring it out. Did you hook up your EFI live and check the o2's? I would look into that as well.
