Annoying belt squeel when cold
Well heres the deal. Right now that temperatures are dropping I got back my annoying belt squeel. I was not able to hear or notice anything at warm temperatures, anything above 70ish. Anytime it is cold the car squeels seems like the colder the louder it gets. It doesn't matter if its from it being overnight parked or after its fully warmed up its squeels either way. I've replaced the belt, idler pulley and belt tensioner pulley. I also have an slp underdrive pulley. My ps pump pulley was cracked so I also replaced it with one from GM. I'm running out of ideas on what it could be. My alternator isn't that old either and it has a overdrive pulley on it, like I said the car was fine with warm temperatures but it does not seem to like cooler temperatures. At times after I've been driving the car and I park it i seem to hear a faint squeek squeek squeek as if something was still turning but I am not able to pinpoint to what it could be. The car doesn't overheat or anything so I don't seem to think it could be the water pump internals going bad. Any ideas on this?
I am honestly thinking the same thing because now after a drive when I park I see a puddle under the car. I tasted it and yup its antifreeze I just have to find where exactly the leak is coming from... its driving me crazy.
Well I know its not the ac pullies ran the car without an ac belt and squeel was there still. I tracked down my leak to the back of the motor.it was a leaky heater hose thats now fixed. But squeel is still there. Like I said before replaced all the pullies bt no go. So kinda out of ideas...
Well same here the dressing makes it worse. I've had that noise even before the ud pulley came Into the picture. My car only squeels loud when the outside temps are below 70ish. It doesn't matter if I drive it for 30 min car still makes loud squeel.
ya i have the same prob, i also have a underdrive pulley. i use the crazy grease at work but it only works for a few weeks the the noise comes right back. it only started after i have put my water pump in a year ago. Pos napa parts
If u need replace the belt, i recomment good year gator back from autozone. That dam thing alway run quiet. if u have belt problem, but if u have pulley, then ether regrease the pulley
BTW DID ANY ONE NOTE THAT sOME PULLEY CAN BE REGREASE ?
Hi,
i would go to the local parts store and do a pressure test on your cooling system. Just pump the pressure to required limit and it will leak..... If you have water pump or hose issues. Use a stethoscope or piece of rubber hose and listen...you should be able to isolate the noise......most likely to be a bearing if belt is not worn out.........check idler tension also..............merry christmas..........
Jim
Jim
Do the fans continue to spin after you turn the car off? Like for a second or two. Because I can here mine sqeek after I turn the car off for a sec. Somethin keeps spinnin after the cars off and thats whats makin noise.
My Firehawk does the exact same thing on a cold start. It all started after I installed my Procharger. I changed idler pully, belt tensioner, both belts, and still squeal. It makes my hawk sound like a POS. There are no visible leaks under the car so i have no idea what it may be. When I changed my belt, the squealing stoped for about a week, then it started up again. I have no idea what it is
