SeaFoam? your take?
Old 02-01-2011, 10:49 AM
BrandonM1004's Avatar
Default SeaFoam? your take?
Need some advice, I am about to pick up my first F-Body in another week or so, the car is a 2002 B4C from CHP, the car has over 200,000 miles on it everything is still going good on it, the water pump was just replaced (with in the last 3 or 4 thousand miles) then head gaskets are probably up for a change.
I want to do a tune-up on it when i get it (coolant flush, oil change, air filter w/lid etc.) and I was thinking about seafoaming it before hand and i wanted your take on it
What is your take on using Seafoam on a LS1 with over 200,000 miles on it?
I'm really excited to finally have a Camaro, I've always wanted one since 7th grade, now i have one and i want to keep it running at its best
Old 02-01-2011, 11:21 AM
_Adrenaline_'s Avatar
Be ready to find all of the leaks you did not know where there.
Old 02-01-2011, 11:24 AM
LS1T56FTW's Avatar
If you are pulling the heads off to replace the gaskets, you can clean the top end of the motor MUCH better than seafoam ever will.
Old 02-01-2011, 11:27 AM
TankTheTurtle's Avatar
I wouldn't put it into the oil, with 200k miles that could be a bad idea.
Old 02-01-2011, 12:58 PM
zracer323's Avatar
I wouldn't do it with that many miles
Old 02-01-2011, 03:04 PM
ULTIMATEORANGESS's Avatar
https://ls1tech.com/forums/general-l...gm-motors.html
Old 02-01-2011, 03:30 PM
kcs02ta's Avatar
ive done it to blazer trucks etc with 175 plus in the oil and gas etc never had a problem.
Old 02-01-2011, 08:12 PM
senicalj4579's Avatar
Use the seafoam. It works
Old 02-01-2011, 09:31 PM
garygnu's Avatar
it won't fix any thing or make it faster.save your money for other stuff.do a compression test .
Old 02-02-2011, 07:21 PM
zracer323's Avatar
Thats why I wouldnt use it on a high milage motor. It can clear out junk that is currently preventing leaks, holding things together, etc.
Old 02-02-2011, 09:05 PM
DeLaRosa25's Avatar
Ive used it on my Camaro worked great. And use it once a year
Tried it ONE time in my T/A this past summer, boy did it make it run like crap, and for about a week. Never again will I use it on my T/A.
Old 02-02-2011, 09:34 PM
Adam2001WS6's Avatar
I used Seafoam and it worked for me without a hitch. I wanted to try the rivaling MCCC, but my engine blew and I replaced it with an LS6 instead! I would still try it though to see how it worked. It SOUNDS better than Seafoam, but I can't confirm actual results.
Old 02-02-2011, 10:00 PM
Talking
try some marvel mystery oil too.
Old 02-03-2011, 08:32 AM
I was gonna say something in my first post about it but I didnt feel like turning this thing into a stupid debate but you asked for it. To blame seafoam for causing leaks is just really dumb plain and simple. If your depending on built up sludge to plug your ******* leaks in you high performance 5.7 then your car is fucked to begin with. Complete non-sense.
Theres my opinion since you had to quote me.
Op, use your seafoam it will be great. I use it on all my cars and always have. Used it my my 155k+ beater car civic, all ls1 cars, and cars before that. Oh and yes, I even tried MCCC and it was the only one to kill an o2 sensor and give me missfires. Just giving the facts of "MY" experience.
There, im out. Fight over what I said all you want. I dont really give a ****. Peace
Old 02-03-2011, 09:09 AM
gottallovepower's Avatar
^ Inferiority complex? Just kidding man. But with 200k+ already on the car....I don't know how much of its "high performance" will last. That raises another interesting question. How many miles has your LS1 or LT1 gone without having to overhaul it? Mine popped a little over 100k. I wasn't the owner then bought it after they completely overhauled it.
Old 02-03-2011, 10:58 AM
01ssreda4's Avatar
Seafoam is the devil. Stay away.
Old 02-04-2011, 08:30 AM
LOL sorry it was one of those days. IDK man, all I can say is my dad has used it for MANY years, iv used it for 10, and I have only heard a couple stories that seafoam is bad. How can anyone prove anything at all?! I seriously think it dosent matter how many miles is on an engine. All its doing is cleaning it out a little. Honestly, I really think its disneyland fantacy to think seafoam is gonna hurt you engine. Just as long as you dont dump it in to fast so that you dont hydrolock it but that goes for any engine with ANY miles on it. Just my .02 bud
Old 02-04-2011, 09:15 AM
t/a98's Avatar
I can't prove it's bad. It does clean your engine very well. But my ls1 blew shortly after I used it... Only 107k miles.
If you want to clean it up go for it.. I'm not convinced I felt a difference though... Other than the loud knock that started haha...
Old 02-04-2011, 09:46 AM
First off this is a boat engine not a car but just relaying the info. A boat mechanic friend hated the stuff because it was so strong that it would knock crap off the gas tank and that stuff would run through the engine causing more problems. Two days before though I saw a guy in the parts store buying it and he swore up and down by it. I guess its just one of those deals where it works great for some people and not so hot for others.
Old 02-04-2011, 09:54 AM
deelong4002's Avatar
I used it on my LS1 with about 60k. Honestly it made my car noticeably better. I'm usually not for gimmicks but i took my father for a ride before and after, and he was like "my god what did you do" and then i told him all i did was seafoam. I used to have a slight lowend throttle hesitation, that was almost entirely cured.
I also couldnt believe the cloud of black smoke that poured out afterward.
Quick Reply: SeaFoam? your take?
