new socket for front turn signal?
Do any of you know where I can get a new 3 way socket for the front turn signal on my car? Rock auto has them for $45 but I wanted to see if I could get it any cheaper somewhere else.
I have new led switchbacks that I went to put in the other night when I found that one of my sockets was fried. I just picked up two new sockets and two electronic flashers from autozone for $35! Thats cheaper than rock auto wanted for just one socket. Thanks for your help guys.
Save the manuals!
Here. Fix if for 50 cents!!!
https://ls1tech.com/forums/general-m...t-gaskets.html
https://ls1tech.com/forums/general-m...ng-insert.html
Delphi makes a special high temperature socket for these bulbs, but... they weren't used in our cars and I can't find a single place that has them in stock. Honestly, its far less expensive to replace the bad parts over and over again rather than getting the heavy duty housing as a special order. (The replacement sockets at the auto parts stores are the regular duty.)
The DRL bulbs are hot and they are going to char the sockets right away. No big deal. If things get bad, you can replace the insert and/or socket housing for pennies. AND - you don't need to splice anything in, keeping the whole setup good as new.
