Traction control
Old 06-27-2011, 03:38 PM
Cheezebandit's Avatar
Default Traction control
well I just bought a 2002 Pontiac Trans AM it was broken into and is missing the traction control switch bezel and the wire pigtail connector for the traction control switch ... I cant find anyone that sells the parts to fix it ...
Does anyone know where I can find the parts to fix it?
Old 06-27-2011, 03:54 PM
NC01TA's Avatar
My understanding was that the dealerships could get parts for 10 years. I have yet to strike out on anything that I have needed. If your local dealership (Chevrolet for me locally) says they can't get it, try another one. Your car is still just 9 years old. Good luck!
Old 06-27-2011, 04:17 PM
I was told by the dealer it had been discontinued ...just got off the phone with a 4th dealer in the area .. and same result
Old 06-27-2011, 04:37 PM
1996firebirdformula's Avatar
Check Classified people part out cars on here alltime.
Old 06-27-2011, 04:52 PM
the problem I am finding is the wire end connector not sure that someone will want to cut it off a good dash harness...I am not opposed to buying a dash harness if it will fix it ...
Old 06-27-2011, 05:05 PM
Have you called local salvage yard or junkyard? Ask if have any firebirds or trans am 98-02?
Camaro might have same harness but switch is diff.
Old 06-27-2011, 05:23 PM
they aren't much help around here they just say "well come down and look we might have one" ..
Old 06-28-2011, 08:48 AM
NC01TA's Avatar
That's not good. I don't like hearing that. Thanks for the info. Sounds like you may just have to take a few hours and hit the salvage yard in person.
Old 06-28-2011, 10:07 AM
jam01's Avatar
year one or similar resto parts house?
Old 06-29-2011, 05:11 AM
myk
myk's Avatar
So you need the bezel and the wire that connects the switch to the harness? I'd try GMpartsdirect.com...
Old 06-29-2011, 09:26 AM
The Scammer Hammer
dr_whigham's Avatar
Just go in the sale section and look for the parted out cars. It's going to be hit and miss. Some will cut, some won't. You won't know till you try.
PM BADBOYZ28 or Ego Killer. I swear those guys have a damned salvage yard at their houses.
Old 01-16-2012, 03:10 AM
well i found a switch and bezel with a wireconnector out of a V6 car
does anyone have a pic of what wires go what spot on the connector?
Quick Reply: Traction control
