Hesitation between 2500 - 3500rpm
Old 08-05-2011, 11:13 PM
Jmac29's Avatar
Default Hesitation between 2500 - 3500rpm
My buddy has a 99 z28 m6 with 83k on it, only mods are slp loudmouth catback and a descreened MAF. We ran a code came up as the 02 sensors after the cat.
When driving the car it hesitates like crazy between 2 - 4k rpm .. could this be the 02 sensors?? Ive read its most likely the MAF but i really have no idea.. Please help!! Thanks guys
Old 08-07-2011, 08:39 AM
blk/slvr02ss's Avatar
Well just switch it out w/ yours and u will know if it the MAF or not !
Old 08-07-2011, 02:21 PM
WhiteKnight '01's Avatar
Did you keep the cats on with the SLP Loudmouth? That could affect the codes.
Just my opinion, but a descreened MAF is bad idea, **** can get in there.
Old 08-07-2011, 07:05 PM
Jmac29's Avatar
the cats are still on the car it has the stock y-pipe.. where gonna try switching the mafs see if that narrows it down
Old 08-09-2011, 06:02 PM
00_Trans_Am's Avatar
Change the MAF, you can thank me later.
Seriously though, mine was doing all the same ****, throwing CAT and O2 codes and I replaced both cats and all 4 O2's until I read about the MAF problems, replaced my MAF and my car is back to being an animal.
Old 09-07-2011, 11:47 PM
blk95formula's Avatar
I agree descreened MAF is probably causing the problem
Old 09-09-2011, 08:12 PM
blitzace12's Avatar
Sounds like a clogged cat. Do a pressure test in the pre cat 02 sensor hole. Relativly any pressure when you rev it = clogged cat. Any rattlling?
Old 04-03-2014, 11:25 PM
Snake_Skinner's Avatar
Old i know but hey Jmac if/when you switched out maf's did it resolve this problem?
Just noticed my car has a slight hesitation everytime RIGHT at 2500 rpm's, i know one of my cats is good bc it got replaced by warranty but not sure about the other but i dont hear any rattling, also i do have a descreened maf and have never cleaned it really.
Old 12-10-2014, 06:37 PM
Drag0's Avatar
Did anyone ever figure this out same problem here. I also got lt's and my car has a hesitation around 2500rpm to maybe 2700rpm. Checked the plugs, wires, maf appears to be clean(no dirt stuck in it ) Im thinking its either the maf or 02 sensor. Can anyone who had this problem please help out
Old 12-10-2014, 07:10 PM
red_00z28's Avatar
unplug the maf and take it for a test drive. Had this problem. Ended up being a dirty maf.
Old 12-13-2014, 04:20 PM
Redlined2000SSLS1's Avatar
Do you have a K&N or any other oiled filter? I had the same hesitation in my SS. Cleaned the MAF and replaced that piece of junk filter and it's a different car. My dad is a GM tech, he said that he has seen that over and over again with K&N air filters.
Old 12-15-2014, 11:19 AM
Drag0's Avatar
guys i figured it out it was a dirty maf sensor. The damn k&n filter caused it
Thanks for the help appreciated it
Old 12-20-2014, 04:25 PM
BlkZMD's Avatar
That's crazy, I would have never suspected the air filter.
Old 12-23-2014, 02:51 PM
chrysler kid's Avatar
I am against k&n for that reason.
I also prefer cleaner air than more volume.
Quick Reply: Hesitation between 2500 - 3500rpm
