Rack in Pinion
Old 10-17-2011, 04:48 PM
T.A.Chick.'s Avatar
Default Rack in Pinion
Well guys it has been a while! Anyways I'm replacing the Rack in pinion in my car. I'm looking into buying one. Quality not quantity here. My first instinct was to go to my local GM and buy one there but i'm not sure if i could buy one to make a difference so I can improve the performance in my car.
Thank YOU!
Old 10-17-2011, 04:55 PM
ULTIMATEORANGESS's Avatar
Smile
do you mean rack and pinion or ring and pinion.
sorry for misunderstanding.
Old 10-17-2011, 05:11 PM
T.A.Chick.'s Avatar
No lol. My bad. its rack and pinion.
Old 10-17-2011, 06:50 PM
38DD2436's Avatar
Buy a quality rebuilt. I did mine and got a 3 year, 36K warrantee on the rack. Cardone is the rebuilder.
Old 10-17-2011, 09:46 PM
sjsingle1's Avatar
GM does not offer new racks.......you can get a GM reman tho
Old 10-18-2011, 12:02 AM
DropTopBird's Avatar
I got a remanufactured one from a place on ebay called Detroit Axle. Its been holding up great and has a lifetime warranty. Once you send back your core it was like $135. Definitely worth checking out:
http://www.ebay.com/itm/1998-02-CAMA...ht_3111wt_1112
Old 10-24-2011, 03:04 PM
Jr.Samples's Avatar
Seen Cordone on ebay for 130.00 plus a 15.00 core. Yup free shipping too. Can't beat it.
Good luck.
Old 10-24-2011, 04:04 PM
vincew1's Avatar
I picked one up at Advance Auto. It is Cordone and I want to say it has a lifetime warranty. One problem: fluid lines on the front of the new Rack and pinion were bent, kinked and had been painted. A little disappointing considering I would expect better.
So I swapped out the lines on my old original unit, cleaned them out with brake cleaner and put them on the new unit. Returned my core with the bent lines and everything worked out great.
I did all this while I was rebuilding my front suspension and bushings. If this is your first time replacing the R&P good luck with getting the bolts out. One of them had to be cut with a recipro saw as it is upside down. The alternative was jacking up the engine. And you will need an alignment after the install...
Good luck!
Quick Reply: Rack in Pinion
