2nd to 3rd hits rev limiter
Old 12-12-2011, 11:25 PM
Justinktm's Avatar
Default 2nd to 3rd hits rev limiter
i have 410 gears and got a tune and everything but somtimes my 2nd to 3rd bangs rev limiter and then shifts would my 2nd and 3rd clutches be going out i have a 3600 stall so what could be the problem??
Old 12-13-2011, 04:57 PM
Justinktm's Avatar
Bump....
Old 12-14-2011, 01:15 PM
BlackLS1Bird's Avatar
My buddy's 99 TA developed issues with hitting the rev limiter before it would finally kick from second to third. Not long after that, on a road trip, the car wouldnt shift from second to third at all. He replaced the tranny with another one he already had laying around but I personally think it was the shift solenoids going bad and finally crapping out. Try those first. It is a quick inexpensive fix if it is in fact the problem. While you are in there, do your trans filter at the same time. I hope it is something simple. Keep updating.
Old 12-14-2011, 02:55 PM
Justinktm's Avatar
Ok I will this is happened before and it went this way for several months then one time when I was a about 60 miles away from home it went out I had to drive in second gear with open headers and it sucked ! But I will try what you said where could I get those things at??
Old 12-15-2011, 02:40 AM
chrysler kid's Avatar
Check your Trans fluid level when the car is warm and on a level plane. If it reads slightly low I would put about a half quart in and see if that helps. The Trans is controlled by the computer but the pressure in the Trans can affect shifting.
Old 12-15-2011, 03:26 AM
Justinktm's Avatar
It only does it sometimes what could that be
Old 12-15-2011, 04:16 AM
NVUSZ28's Avatar
X2 on Crystler Kids statement, but what you want to do after you do that, is go back to the person who tuned it, and double check your shift points, just in case he missed them.
Old 12-15-2011, 07:53 AM
Yeah my buddy drove from the Tennessee/ Virginia border to virginia beach in second gear. That **** smelled sooo bad. I got some for the 4L60E in my truck at Advance Auto Parts. Im sure Autozone, Napa and most other places will have them.
Old 12-15-2011, 07:55 PM
senicalj4579's Avatar
I had a problem with hiting the limiter one time after installing a trans cooler. Turns out the fluid was just low.
Old 12-20-2011, 06:55 AM
Any updates on the trans yet?
Old 12-20-2011, 07:31 AM
Blackbeauty1999's Avatar
Default shifting
i am a hp tuner... i would say honestly ur tune is alitte tweeked.. make sure ur misfire codes have been been removed, and ur speed and rmp shift points match... i own a 3600 stalled a4 trans am... had the same problem.. i added shift pressure and played with mph vs rpm tables and it took care of it..if ur running a big cam, a4 ls1 cars will throw misfires and cause spratic lock ups and disenaging... just thought i would throw in them factors, seems that i have personally went all the bs and headache to achieve good drivabiltytrack results...
Old 12-20-2011, 06:03 PM
If it only does it occasionally your probably just low on fluid.
The reason I say this is when I installed a Trans temp gauge I forgot to put Teflon tape on the thread for the sensor. I had an extremely small leak and it eventually caused the car to bounce off the limiter once or twice before shifting.
It never read low, however I knew I lost about half a quart and after topping it off I haven't had a problem in 2 years.
My car has a 3500 stall and cam
Old 12-21-2011, 04:06 AM
Default shifting
thats very true also!!! do al the basics first...lol
Old 12-22-2011, 12:37 AM
Justinktm's Avatar
well im convinced its the tune because it only did it after the tune
Old 12-24-2011, 10:10 PM
99ws6ls1's Avatar
It is. after i installed 3.90's i have the same problem. played with the tune for a while and finally fixed it after i bumped my rev limiter up to about 6200 and set my shiftt point at 6000. when u intall gear et. the engine can carry through the rpm range much faster, the trans doesnt have enough time to build pressure or isnt use to it. bump your 2-3 limiter up and take it out for a spin
Old 12-26-2011, 07:51 PM
Justinktm's Avatar
Well I need a tuner to do that bcuz the tune shops up here suck
Quick Reply: 2nd to 3rd hits rev limiter
