What window motor?
Right here man. I just searched all over. I ordered it from amazon it shipped in 3 days and installed with a breeze. It works awesome, super fast and quite.
http://www.amazon.com/Dorman-742-101...0656022&sr=8-1
LS1Tech Administrator
Received 1,797 Likes
Siemens and Dorman seem to be good replacements. And the install instructions linked above are very good.
The RIGHT way to do it is to put in a new motor and regulator together. Its SOOOOOOO much easier to do as an assembly. Plus one bad move and that spring comes unwound - now your taking the regulator out anyways. Just do them both together and only have the door apart once, save yourself some trouble.
You replaced just the motor and it still works? You got lucky
It is super easy to replace just the motor once you drill the access holes to remove the motor rivits.
I have to replace both motors and drivers side regulator, is there a write-up or video anywhere on replacing the window regulator? Any help would be appreciated.
