TBSS stabilitrak and ABS problems
Old 07-07-2013, 09:21 PM
ShowStopper71z28's Avatar
Default TBSS stabilitrak and ABS problems
I have a 2006 TBSS. I am having problem with the stabilitrak and ABS. Stabilitrak used to come on every now and then just at take off. It would come on for approx 2 sec then cut off. I took the wheels sensors out today to check them and clean them off. I took the TBSS for a drive and now ever time i take off the stabilitrak comes on but stays on longer. Also when I am breaking right before i come to a complete stop the ABS kicks on. The previous owner replace the throttle petal assembly, key switch, and break switch.Is there any way to tell if a wheel speed sensor is working properly or not.
thanks for your help.
Old 07-08-2013, 06:41 AM
Save the manuals!
wssix99's Avatar
You need to find someone with a scanner that can read the ABS system. Then you can scan it for codes, which may give you some clues.
Old 07-08-2013, 09:57 AM
I do not have any mil lights on on the dash. Could I still have a ABS system code. Can hp tuners read abs codes?
Thanks
It's not mine! woo hoo!
demonspeed's Avatar
May also be a steering position sensor.
Old 07-08-2013, 11:02 AM
How would I check to see if the steering sensor was the problem?
Old 07-08-2013, 11:47 AM
demonspeed's Avatar
When you scan it. It's part of the Stabilitrak system and is a very common part that needs replaced on GMT360's.
Old 07-08-2013, 01:50 PM
Save the manuals!
wssix99's Avatar
Thanks
sure. I understand you should bet a code every time the ABS light comes on.
Old 07-09-2013, 08:33 PM
Ok i will check. Can hp tuners read abs and stabilitrak codes, or do i have to take it to the dealership?
Thanks
Old 03-19-2014, 04:20 PM
csambuco's Avatar
2008 Chevy Impala SS - Service Stabilitrak Light occasionally activates at start up with vehicle at rest. No codes set. Clear incident by restarting engine. No issues while vehicle is in motion. Any ideas?
Old 03-20-2014, 11:55 AM
User_name's Avatar
I have the same problem on our 06 TBSS. I went for a drive the a tech2 and all the wheel speeds were correct I did some searching on the trailblazer forums and a lot of the time it was the steering angle position sensor. I will be replacing that come spring, or whenever it actually warms up and I will see if that fixes the problem. You can manually turn the stabilitrak off by holding in the button on the left side of the shift lever for like 5 seconds so you don't have to worry about the abs kicking on while you're driving.
Quick Reply: TBSS stabilitrak and ABS problems
