Burnt oil smell
Old 07-13-2013, 05:21 PM
DirtyBirdMKE's Avatar
Default Burnt oil smell
After i get on it a little bit and then slow down, i smell burnt oil sometimes. I checked my oil and its gone down a little bit. Not very much... No oil on my garage floor.
Any Ideas??
98 TA WS6 M6
Old 07-14-2013, 02:02 AM
_JB_'s Avatar
Next thing to check would be blue smoke coming out of the exhaust. Blue smoke when reving the engine=rings. Blue smoke when leaving the car in gear, getting to high RPMs, and letting off the gas usually means valve seals.Then again, oil could be entering the inake from the PCV system as well.
Old 07-14-2013, 08:50 AM
no smoke on start up or when reving..... could be valve seals... i know the PCVs in these cars suck donkey *****
Old 08-02-2013, 12:16 PM
kamesama980's Avatar
I was gonna say valve seals too. PCV is my second guess. could be rings too since it's after hard runs (obviously you aren't going to smell it while moving but if you come to a stop with a tailwind blowing, you'll smell it.)
Old 08-03-2013, 07:51 AM
im thinking its the valve seals or pcv... im going to do a new PCV valve and Husky catch can soon
Old 08-06-2013, 08:06 PM
2000PewterT/A's Avatar
Check to see if your PCV system is working correctly before doing anything else. The catch can is a worth while investment.
Old 09-03-2013, 04:16 PM
UPDATE: I havent driven the car that much. Today i was going to do my clutch fluid (Ranger Method) and was moving a hose out of the way when i saw that the PCV hose that wraps around the back of the intake manifold from the drivers side valve cover was broken completely off.
Old 09-12-2013, 05:05 PM
sabersaw30's Avatar
My car does the same thing with a catch can. I think mine is just built up carbon.I dont run my car as hard as i should.Crank on it a few times and the smell goes away.
Old 09-26-2013, 01:44 PM
FirehawkChris's Avatar
My car does the same thing. I checked the PCV itself and it was fine. I guess I need to check all the lines.
Old 09-28-2013, 11:38 PM
check the lines and the Y fitting on the back
Quick Reply: Burnt oil smell
