Green brake fluid wtf GM
Purchased car, sick project in need of finishing. However, I am stuck with infamous green stinky brake fluid from copper brake down. God knows when the last "owner" changed anythng, so flushed and filled all fluids except the brakes.
I am debating running lines, r any mastery you guys have come across, from searching it seems some people run into problems w abs modules etc.
Any tips or suggestions on approaching bleed I so badly need to get her back on rd before the snow hits.
i just did my 2006 sierra, hard line blew going to the rear because of rust and road salt. before that i had green brake fluid, ended up replacing the master cylinder because the plastic res. was so full of debris which wouldn't clean out. so i had replaced all hard lines, I had no problem with the abs block. I used a motive power bleeder to push fluid through. It seems everyone who does the old fashioned method of one person pumping the brake pedal and the other doing the bleeder screw is insufficient. I've also pushed air into the master on my camaro but had no problems after bleeding using the power bleeder. if you don't pony up for a motive power bleeder you can make one out of a garden sprayer bottle that will pressurize to 5-10 psi, then all you need to do is get a fitting for the master cylinder reservoir or buy just the cap from motive. you don't need a power bleeder that feeds brake fluid to the master cylinder reservoir and i recommend you don't do it that way because it will make a mess. you only need to pressurize the reservoir and stop bleeding before it empties then refill.
i just did mine.. mine was green ans shitty... got the new AC Delco SUper DOT4 fromthe dealershit for $12 a bottle... bleed brakes well, Ranger Method the master cylinder a few times
Motul RBF600 is good stuff too
After you flushed out and bled the brakes, did you notice any changes? Did you see any change in pedal height or firmness?
